timing
Old May 8, 2006 | 09:58 PM
cooky's Avatar
cooky
timing
I have a 1979 F250 trailer special.
Dropped a new 400 in it last june.
The only vacumn I have hooked up is Brakes dist pickup trans heater.
My question is does any one know what my timing should be set at?
I shold mention it is a 2 barrel
Old May 8, 2006 | 11:26 PM
whalerron's Avatar
whalerron
Try setting it at 6 degrees BTDC. Then, drive it and keep bumping it up about 2 degrees until it starts pinging. From there, drop it back 2 degrees or so and it should be fine. I think the final timing setting will be around 6-8 degrees BTDC.
Old May 8, 2006 | 11:42 PM
Mil1ion's Avatar
Mil1ion
Auto trans ?
49 state or california ?
4x4 or 2x4 ?
Old May 9, 2006 | 06:36 AM
cooky's Avatar
cooky
Auto trans Ohio
Old May 9, 2006 | 06:37 AM
cooky's Avatar
cooky
Auto trans Ohio 2 wheel drive
Old May 9, 2006 | 02:49 PM
Mil1ion's Avatar
Mil1ion
Your calibration code is 7-74-R10
Timing is 12* BTDC
You can view the specs on this page.
Just look for that code in the 2 nd half of this page.
http://mil1ion.clubfte.com/78Calibra...e-upSpecs.html
Old May 9, 2006 | 05:26 PM
Mil1ion's Avatar
Mil1ion
I just realized that the above diagram is for a California application.
I am presently trying to upload a copy of the actual vacuum diagram you need.
Old May 9, 2006 | 09:01 PM
Mil1ion's Avatar
Mil1ion
Well it took long enough.
Here it is.
http://www.clubfte.com/users/mil1ion/7_72_R11.JPG
Old May 9, 2006 | 10:34 PM
whalerron's Avatar
whalerron
When you get the timing set, I am curious to hear if you can actual run 12 degrees of timing without pinging when using 87 octane gas. This new gas is really bad as far as pinging is concerned.
Old May 9, 2006 | 11:29 PM
Mil1ion's Avatar
Mil1ion
Pardon my last few posts.
I was posting on the wrong thread.
Too many windows open
Old May 10, 2006 | 09:37 AM
beartracks's Avatar
beartracks
You really should get the vacuum advance working to help with pinging and gas mileage.
