Another Tranny Question
Old May 8, 2006 | 09:20 PM
TiogaKid's Avatar
TiogaKid
Hello all, this is my first post. iIve been lurking around for over a year. Usually I can find all of the answers I need, so I never post a question. So here goes...
I have the dreaded blinking OD light. I had the code pulled. P0741. Dealership
wants $88 to tell me what is wrong. One tranny shop said needs new converter
$800, Another said needs complete overhaul. Problem is neither shop even test drove the truck. It shifts thru all gears. It starts blinking after I reach 50 mph.
Please help.
Old May 8, 2006 | 09:28 PM
jtharvey's Avatar
jtharvey
My code list says this: P0741 TCC Circuit Performance.
Not sure what TCC stands for, possibly something do do with the torque converter?
Old May 8, 2006 | 09:41 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Banks uses that term. Torque Converter Clutch. basically the whole thing, it's a clutch
Old May 8, 2006 | 09:45 PM
IABill's Avatar
IABill
Wink
TCC Usually refers to the Tork Converter Control circut. Get it to a chain shop like AAMCO or even Cottmans most of them will do diagnostic for no charge, scan codes and drive truck some will even pull pan & inspect sump. just keep an eye on them thier job is to sell transmissions keep that in mind. And now that Cottmans has bought AAMCO corp there about the same bunch of guys. The Cottman stores have three years to change the name to AAMCO....AHHH that 80% market recognition paid off for something.
Old May 8, 2006 | 09:47 PM
TiogaKid's Avatar
TiogaKid
Everthing I find on this code says it is electrical failure. I think it may be the Solenoid Pack. But I was hoping I could hear a few more sugestions.
Old May 8, 2006 | 10:28 PM
jtharvey's Avatar
jtharvey
I figured is was torque converter something or other. I just couldn't put my finger on what the last C would be for in TCC. It definately sounds like something electrical though. Perhaps the TC lock line has a short in it somewhere?
Old May 9, 2006 | 07:45 AM
Casey's Avatar
Casey
TCC = Torque Converter Clutch.
P0741 means the electrical circuit for the TCC solenoid has an open or a short. It can be in the wiring or it could be a bad solenoid. Someone needs to do an electrical diagnosis to determine where the problem is.
Old May 9, 2006 | 07:56 AM
TiogaKid's Avatar
TiogaKid
Well I took it to the dealership this morning for them to do a diagnosis.
I'll keep my fingers crossed that it is nothing major.
Old May 9, 2006 | 11:29 AM
TiogaKid's Avatar
TiogaKid
Well they said the Solenid pack needs replaced.
Anyone ever do this on thier own? If it something I can do at home, I will also add the BTS valve body at the same time.
Old May 9, 2006 | 11:44 AM
cangim's Avatar
cangim
yes you can easily change the solenoid pack out, it is almost the same as changing out the VB. Onlyl difference is you need a #30 torx bit and 10mm socket. A long arm to reach over the tranny crossmember to disconnect the electrical for the solenoid block. I have a few pics in my gallery, feel free to ask any questions. I fyou are doing the VB you minus well do them both as the majority of the work is draining the pan removing it and putting oil back in. Should only take about 10 min for the solenoid pack. If you do it, you can fit your hand between the heat shield and tranny, push down on the connector the same time as gently pulling a wiggle it out. It will be MESSY though, same as the VB, lots of oil in there.
Old May 10, 2006 | 08:16 AM
TiogaKid's Avatar
TiogaKid
Talking
Well I guess this gives me a good reason to make the leap. I called Brian and spoke with him about this work. I'm now going to order a new solenoid pack and a BTS Valve Body from Brian.
Old May 10, 2006 | 09:14 AM
jtharvey's Avatar
jtharvey
BTS - great stuff!! Brian - great guy!! I think you'll be pleased with the performance of the VB, and once the DP chip goes in, which Jody will program for the chip, it'll be even better. Just don't forget to tell Brian that you're getting a DP chip. He'll adjust the VB for the chip.
Resendiz
Feb 17, 2017 04:58 PM
CASHER0010
Mar 27, 2015 03:59 AM
Nick_L
Mar 16, 2015 06:04 PM
HeyMoe
Jul 15, 2006 07:52 AM
jgibson3
1997 - 2003 F150
Nov 30, 2004 12:24 AM
