Edelbrock cam
Old May 7, 2006 | 08:52 PM
IowaTower's Avatar
IowaTower
Edelbrock cam
I have a 351M with an Edelbrock 2172 cam in it. We think the previous owner lost the oil-pump and upper-end -- new camshaft, lifters, etc. and oil-pump -- and neglected the lower-end -- it smokes like Keith Richards.
I've got one 351M that I want to freshen-up, possibly do a mild upgrade. Another, I'm hoping for something close to Hot Rod's 400 HP build when it's all said and done .
Is the 2172 mild or wild? I'm trying to decide if I should pull it for one of the target engines, or if I'd be better off leaving it and rebuilding the lower-end as a spare.
Old May 7, 2006 | 09:05 PM
danlee's Avatar
danlee
Edelbrock makes some nice stuff, but based on the 2172 cam, they should stick to manifolds.
What kind of use do you plan for this motor. A stump puller, or tow a trailer at highway speed, or run around town burning gas and sounding bad.
Look at Comp Cams 255DEH or XE256 for the stump puller, or a 265DEH or XE268 for the highway speed motor.
Old May 8, 2006 | 07:34 AM
IowaTower's Avatar
IowaTower
Bah. I was afraid I'd hear something like that.
What kind of performance can I expect from the 2172? I've got it; I might as well use it in something. Thumping street-cruiser?
Old May 8, 2006 | 08:21 PM
danlee's Avatar
danlee
The Edelbrock 2172 cam has slow ramp rates. They do this so they can use weaker springs. As a result the cam has lower lift, more overlap and later Intake Valve Closure than a cam with similar duration and faster ramp rates.
The lift of the 2172 is probably adequate for a stock 400 head, but the late IVC will hurt the low end torque. The increased overlap will make the idle a little lumpy, but do little else positive.
As a result, the 2172 cam is not a good choice for a motor with high torque at low RPM, or a motor with a wide torque curve, or for high RPM performance. In my opinion it fails on all counts.
You should try to sell it, and buy a cam that is suited for what you want your motor to do.
What do want out of your motor? I'll suggest some better cam choices.
Old May 8, 2006 | 09:34 PM
IowaTower's Avatar
IowaTower
This particular motor, I'm not sure. It's currently sitting in a '78 Marquis that, I think, was intended to "run around town burning gas and sounding bad" -- lots of show & rumble on city-streets. I bought the car mainly for parts for one of my project trucks -- Sunpro tach & cluster, Edelbrock intake & 4bbl, American Racer rims, new tires, oil & fuel pumps, fan, chrome valve covers.
I want a (mostly) stock daily-driver & a showier stump-puller -- two different motors that I already have in progress. Or intended to be in progress. In the planning stages. OK, a distant dream. This third engine, I don't know -- the best idea I've heard so far is to swap on stock parts for the aftermarket ones I remove, then sell the hulk for a demo derby.
Old May 8, 2006 | 10:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
Originally Posted by IowaTower
...I want a (mostly) stock daily-driver & a showier stump-puller ...
Sounds like a nice fit for a comp cams 255DEH.
Old May 9, 2006 | 07:21 AM
danlee's Avatar
danlee
I'll second that!
Old May 10, 2006 | 01:01 PM
tastyklair's Avatar
tastyklair
The edelbrock cam youi have works well when your'e having a party with a pinata. It doesn't take too many wacks with that thing to bring it all down.
351Cleveland C4
21
May 12, 2014 03:49 PM
triplecreek
Mar 31, 2010 12:13 PM
hdavid66
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 12, 2005 05:19 PM
sonnysweet
Mar 24, 2005 06:46 PM
rotorhead
Aftermarket Products
Jan 13, 2002 06:54 PM
