Performance on a 351m
Old May 8, 2006 | 06:00 PM
77ford guy's Avatar
77ford guy
Talking Performance on a 351m
Hey! How can i get some cheap horsepower for my 351m. I wanna add a bit of power. Thanks.
Old May 8, 2006 | 07:03 PM
Twinscrew's Avatar
Twinscrew
Nitous Oxide. Biggest bang for the buck. Nothing else even comes close.
Old May 8, 2006 | 10:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
Turn it into a 400 and check some of the builds here in this forum. Otherwise-
#1-Straight up timing chain
#2-Headers and free flowing exhaust
#3-4V intake and Edelbrock carb #1406
#5-New cam, comp cam #255DEH
#6-Engine rebuild, 9:1 compression, contact TMI
Depending on the age of the engine #1 and #2 may interchange. The stock OEM timing set is only good for 80-100K miles and is retarded 4° initially for smog and is retarded substantially more due to wear. If it has been replaced by a good straight up timing set then proceed to #2.
Old May 10, 2006 | 01:04 PM
tastyklair's Avatar
tastyklair
If you have many miles on the engine the nitrous may well give you the most bang for the buck. Then you have to come up with a lot more bucks before you can bang it around again. Torque1st has it right. It's tried and true with these engines.
Old May 10, 2006 | 05:16 PM
77ford guy's Avatar
77ford guy
I was wondering how much all of that would cost for parts? I can do most of the work myself.
Old May 10, 2006 | 05:20 PM
mattselland's Avatar
mattselland
tourqeu 1st do you have any idea what the horespower range for the motor you described would be? I have a very similar set up and im just curious.'
