Wacky temp guage!
Old May 6, 2006 | 03:03 PM
tom1979's Avatar
tom1979
Unhappy Wacky temp guage!
Hi guys, need some help! I have a 1979 F-150 XLT with dash guages and the problem is the temp guage is reading higher than I want for the truck temp. of the engine. I have a manual temp guage that runs at 195* at highway speeds. The stock dash guage will read 3/4 or higer at times. It seems to fluctuate. I remember years ago when I had overheating problems after rebuilding engine; 4 row radiator solved, there was two set screws on the back of the guage to adjust the range or calibrate. Is there a accurate way to center the guage to the running temp of the vehicle with shade tree mech. skills? Thanks for any help!
Old May 8, 2006 | 09:00 PM
Ultramagdan's Avatar
Ultramagdan
If it is changing while rolling down the highway I would suspect a bad sensor or a possible grounding problem. The system is filled to the correct level, yes?
Old May 10, 2006 | 02:36 PM
tom1979's Avatar
tom1979
mega, the guage changes on both tanks (dual) It will show one time full with the tank topped off, then three quarter full the next time I turn on the key. Any thing else to check?
JoeBlow
17
Nov 4, 2005 04:33 PM
sailmfast
Nov 2, 2005 11:16 PM
mgundry
Electrical Systems/Wiring
May 31, 2004 11:46 AM
Rick Pry
Jan 23, 2004 01:05 PM
johnappleseed
Dec 30, 2003 10:19 PM
