temp guage reading extremely low
Old Dec 30, 2003 | 06:32 AM
johnappleseed's Avatar
johnappleseed
the temp guage on my 98 exp sport 4.0 seems to have stopped registering. if i run it for an extended period of time the guage will barely crack the L. any suggestions?
Old Dec 30, 2003 | 08:37 AM
AJobWellDone's Avatar
AJobWellDone
I've had the same problem with mine for more than a year now. I've already replaced the sending unit, so I'm thinking maybe it's the guage itself. If you find the answer let me know.
Old Dec 30, 2003 | 09:19 AM
CobraXP's Avatar
CobraXP
Have you changed your thermostat lately? If it is stuck in the open position, your X will not heat up...
P.S. - Welcome to FTE!
Old Dec 30, 2003 | 01:07 PM
borland's Avatar
borland
How's your gas milage? Poor gas milage is another symptom of thermostat stuck open. When the engine runs cold, the fuel injection system runs rich.
Old Dec 30, 2003 | 02:22 PM
johnappleseed
Thanks for the replies. No I have not replaced the thermostat, but the truck appears to be heating up just fine. It's worth a shot though. I had planned on replacing the sending unit this weekend, but apparently that isn't the answer i'm looking for. And the gas mileage has stayed consistent through this whole thing. Any more ideas? I'll make sure and post when i find the answer.
Old Dec 30, 2003 | 02:25 PM
marragtop's Avatar
marragtop
I'd replace the thermostat first, since it really is part of normal maintenance. Also remember to get the thermostat gasket O-ring. Usually it's sold seperate.
Mike
Old Dec 30, 2003 | 05:04 PM
zogy's Avatar
zogy
I'll lay odds it the thermostat. I had the same problem (<50k miles). Replaced the thermostat and it was fine. One way to tell for such, is to monitor the top radiator hose while warming up the engine. It should stay cold for a while (until the thermostat opens) and then get hot all a once. If it gradually gets warm, then the thermostat is not functioning properly.
Old Dec 30, 2003 | 07:35 PM
ivorycruncher's Avatar
ivorycruncher
I have a similar problem with my 95 Explorer. The gauge does work to a certain degree. While driving down the road, it generally will not go above about 1/4 of the way up the gauge (I'm talking about the part between the little white lines inside the letters). When I pull to a stop, then it might go up to about 1/3, but never more than that even when it's hot out. I'm second owner on the vehicle (got it when it had about 117k miles on it). I suspected the sender and had that replaced at the local dealership. I think it helped slightly, but not to a very noticeable degree. Maybe this is normal behaviour, but to me, it doesn't seem like a very accurate gauge this way.
Old Dec 30, 2003 | 10:19 PM
Blly177's Avatar
Blly177
with the engine warm go to autozone or use an obd scan tool and have the engine coolant temp read from the scanner
kel1306
Mar 26, 2011 07:20 AM
hdman6
Sep 6, 2006 06:19 AM
Mopey
Nov 19, 2004 04:28 PM
restorit
Electrical Systems/Wiring
May 9, 2002 10:32 PM
