saginaw power steering
Old May 6, 2006 | 07:50 AM
buckethead5k's Avatar
buckethead5k
Question saginaw power steering
is there any way to lessen the play in the steering wheel via adjustments to the steering box? If not any recomendations on an aftermarket box
Old May 6, 2006 | 05:15 PM
Ford_Six's Avatar
Ford_Six
There are, but make absolutely sure that the play is coming from the box first, if you adjust it too tight, it will damage the box.
Old May 6, 2006 | 11:39 PM
buckethead5k
yeah its the box, has new rag joint and you can watch the steering column move in the box!!! do you have any Idea what the specs are for adjusting and where to adjust?
Old May 6, 2006 | 11:44 PM
ford390gashog's Avatar
ford390gashog
if the column moves in the box then that is not fixable and is just worn out and needs a new box.
DavidJO
Nov 30, 2016 06:07 PM
wr310rdr
Feb 5, 2014 07:46 PM
R.E.M
Nov 1, 2013 11:35 AM
jamhh
Apr 26, 2013 09:33 PM
jarrott
Sep 1, 2003 01:52 AM
