Sponsored by: Innova
Looking for a new sub
Old May 6, 2006 | 02:48 AM
Bargod's Avatar
Bargod
I have a Jensen XA2125 and a solid box that is tuned to around 36htz and I am looking for a dual voice coil 12. The box has about 2.5 - 3 cubic feet of air space and my only two limitations are the mounting depth of under 6 inches and money. I can't afford to go crazy with the cash. I am looking for suggestions and anything is appreciated. Thanks.
Old May 6, 2006 | 09:52 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
is dual voice that important?
KCAutoSound has one of the pioneer flat-mount subs that I think I'd consider buying.
http://www.kcautosound.com/store/pro...cat=354&page=1
That will have a mounting depth of 4-4.5 probably. Perfect for a truck.
Ryan
Old May 6, 2006 | 11:58 AM
fordboy_52's Avatar
fordboy_52
fighting irish, you... you... awesome awesome man... good find
Matt
Old May 6, 2006 | 08:41 PM
IPACA9's Avatar
IPACA9
Damn good hunting I might say. I just placed those on my store last night about 2:00 am. I dumped all the 05 Pioneer product and installed all the new 06 gear. Not too much has been changed with pioneer. They basically re-skinned the amplifiers and radios it seems and jumped thier numbers up one digit...lol Tonight I will be putting the mobile video product on there like the AVIC-Z1 and some other pieces they offer.
As for depth limitations there are quite a few subs that will get you into those requirements. I'll post a few tonight after dinner and some research. I looked up your amp and I see its bridged RMS output is rated at 350 watts so I'll post some models that will perform under those conditions. Also most 12 inch subs require a recommend airspace of 1.75 cuft. Are you sure of your airspace of your enclosure? Would you be able to post you measurements and I can tell you your exact airspace.
Old May 7, 2006 | 01:20 AM
Bargod's Avatar
Bargod
The airspace is an estimate. The box isn't exactly square. This is a link to a picture of the box before I put the top of it on. The top area of the picture actually comes back around just like the side with the sub and houses the port. I would have to go out an take measurements and it's late, who knows, I could be way off, but it is the full width of my cab, about 6 or 7 inches tall, and about 4 inches longer than my seat across the top. The whole thing is made out of 3/4 inch mdf.
Old May 7, 2006 | 10:22 AM
IPACA9's Avatar
IPACA9
ok.. I see. I was thinking of a prefab enclosure. Pretty slick build. I started out in the car audio business building custom speaker boxes.
Old May 7, 2006 | 10:49 AM
Bargod's Avatar
Bargod
The market for prefab for an F150 is pretty limited.
Old May 7, 2006 | 03:01 PM
FghtinIrshNvrDie
isn't that true? I think the area that my year of truck has is less than the Chevy counterparts. I had to fabricate my own, but after it's all said and done, I was really happy about it. Check the gallery if you want to see. I mean, really. Check it out. Not kidding. Now.
Ryan
Old May 8, 2006 | 06:32 AM
Bargod's Avatar
Bargod
I need to be a 2 ohms, so DVC or a 2 ohm sub.
Old May 9, 2006 | 07:20 PM
Bargod's Avatar
Bargod
Does anyone have any suggestions?
Old May 9, 2006 | 08:31 PM
IPACA9's Avatar
IPACA9
my question to you before I give quite a few suggestions is I need to know your exact depth allowable. You need to factor into it having aleast a 1/4" vent space or more behind the magnet. Also how much room do you have for the excursion of the speaker? With the amount of airspace you have a high excursion subwoofer would work nicely but that all depends on the distance your speaker can move.
The advantage you will have with having that much airspace is that it will take less power to move the sub which will work nicely for that Jensen amp.
Old May 9, 2006 | 10:31 PM
Bargod's Avatar
Bargod
I have roughly an inch to an inch and a half of excursion space, and to allow the 1/4" of vent space, I can have a mounting depth of 5 3/4"
Old May 9, 2006 | 11:14 PM
IPACA9's Avatar
IPACA9
OK. I found a few subs that will fit your depth requirements and work great with the power and airspace.
Soundstream Xstream Series. HERE
Soundstream Picasso Series. HERE
Kole Audio KLE-Series HERE
Kole Audio MFW-Series Shallow Mount HERE
Swiss Audio SW-Series HERE
Swiss Audio SWP-Series HERE
Coustic BP Series HERE
These are all ones that I could find data on them as far as mounting depth that will work with your enclosure. All are manufacturers that I carry.
Old May 10, 2006 | 07:50 AM
Bargod's Avatar
Bargod
Thank you for the replies Travis, PM sent.
sbreadner
Nov 25, 2012 01:11 PM
Randy Kuykendall
Ontario Chapter
Jan 26, 2009 06:39 PM
arno
Nov 28, 2008 06:09 PM
blue 79
Alberta Chapter
May 6, 2003 11:34 PM
