OK, just got a reman. 390, just looking for some guidelines
Hey all, man you guys have been a great help lately, hopefully this will be my last post, other than pics when I get them.
Today I ordered a 390, bored to a 406, I know its scetchy, but it was sonic tested, core shift tested etc. came with a 5 year warranty too, and all the inners are new, only thing re used is block, heads, rods and crank, other than that new everything.
I want to make sure I don't jack anything up when I go to start her up. I am gonna transfer my high volume oil pump from my old engine in, put on my rear sump pan etc. I need to get the thing timed, but I can look that up later.
Question, manually prime oil pump, pressurize oil system to prevent dry starting. Basically the engine is dry, without an oil pump installed, what should I do to get everything pre-lubricated?
Thanks a ton AGAIN
Thanks a ton AGAIN
I personally wouldn't re-use an oil pump from another motor.
If it's warranteed for 5 years, I'd leave well-enough-alone. Did you check if the warrantee is still valid if you swap oil-pumps ???
The 1/4" socket is a good idea. Get a 1/2" reversible drill, a long 1/4" extension and a 1/4" socket and you're good to go. Is it 1/4" or 5/16" ???
