OK, just got a reman. 390, just looking for some guidelines
Old 05-05-2006, 08:37 PM
chinaman's Avatar
chinaman
chinaman is offline
Hey all, man you guys have been a great help lately, hopefully this will be my last post, other than pics when I get them.
Today I ordered a 390, bored to a 406, I know its scetchy, but it was sonic tested, core shift tested etc. came with a 5 year warranty too, and all the inners are new, only thing re used is block, heads, rods and crank, other than that new everything.
I want to make sure I don't jack anything up when I go to start her up. I am gonna transfer my high volume oil pump from my old engine in, put on my rear sump pan etc. I need to get the thing timed, but I can look that up later.
Question, manually prime oil pump, pressurize oil system to prevent dry starting. Basically the engine is dry, without an oil pump installed, what should I do to get everything pre-lubricated?
Thanks a ton AGAIN
Old 05-05-2006, 08:52 PM
Randyb12's Avatar
Randyb12
Randyb12 is offline
Use a drill and a bit extension (the hex is the same as the oil shaft) to turn the oil pump counter clockwise. a 1/4 socket works too.
Old 05-06-2006, 09:25 AM
jor's Avatar
jor
jor is offline
Re the oil priming process, you can get one of these free at AutoZone. The round aluminum piece fits snugly in the distributor hole.
jor
Old 05-06-2006, 09:40 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I personally wouldn't re-use an oil pump from another motor.
If it's warranteed for 5 years, I'd leave well-enough-alone. Did you check if the warrantee is still valid if you swap oil-pumps ???
The 1/4" socket is a good idea. Get a 1/2" reversible drill, a long 1/4" extension and a 1/4" socket and you're good to go. Is it 1/4" or 5/16" ???
