F150 overheating. Need Help.
Old May 5, 2006 | 02:46 PM
waycooljr88's Avatar
waycooljr88
Angry F150 overheating. Need Help.
Hoping someone can give me some guidance. 1994 F150 5.0V8. Continuing over heating problem. I have replaced the thermostat, water pump, fan clutch, and all pertinent hoses. I have flushed the system. Truck can run at idle for an hour and not heat up. When you drive it, it takes about 20-30 miles to over heat. Oil is good. Recently changed. Does not look like any water in the oil. Truck runs great. Cannot find any visable leaks. I have now ordered a new radiator and am trying that avenue. I have been told that if head gasket was bad there would be visable evidence of water in oil and white, smoky exhaust. Truck is nickel and diming me to death and frustrating me a great deal. What else could be causing my problem? Thanks.
Old May 5, 2006 | 05:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
To find out where to ask this question, click on this link
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
rmcewand
New Member Introductions
Jul 28, 2006 05:30 AM
93fordf150
Apr 15, 2006 04:22 AM
Seantl
13
Dec 12, 2005 10:10 PM
joel25
Dec 6, 2005 09:20 PM
mattygeetarross
Nov 22, 2005 08:11 PM
