Sponsored by: Auxito
99 F150 5.4 stalling/missing
Old May 5, 2006 | 09:37 AM
fordguy4life's Avatar
fordguy4life
Hey guys,
I have a wierd probem. First started with a miss after a good rain. SES light came on. Read a cyl #5 misfire. I replaced the COP and plug. Cleared the code. Still misses and now on top of missing, it quits when I shift into gear or stopped. I have to feather the throttle to get it to run again. No new codes. Should I replace all the plugs and the IAC valve? Oh the truck has 135,000 miles and the plugs were replaced around 90,000. Thanks!
Old May 8, 2006 | 07:23 AM
fordguy4life
Well I changed all the plugs. Boy is that fun! Still misses, but it doesn't stall now. Anyone have any ideas. No new codes. Maybe something will show up soon.
Old May 8, 2006 | 06:51 PM
beer boy's Avatar
beer boy
un plug the iac connector. it will set a code but the engine will run at a default setting. try that. as well it seems that the first cop code usually isnt the only one giving the problem. try a new cop one cyl 1, no change re-install originol cop and move to cyl 3, then 5, etc. if you dont find a bad cop then you will have a spare and you will know that all yours are good. i know it doesn't sound right to do this but it can work and its still cheaper than a garage throwing parts at the truck that it may not need.
Old May 8, 2006 | 09:38 PM
golddirt's Avatar
golddirt
try and check the idle sensor.
Old May 10, 2006 | 01:18 PM
fordguy4life
#3 coil. Go figure....
Old May 10, 2006 | 05:34 PM
deltasoft's Avatar
deltasoft
how long should it take for it to throw back the service engine soon code into dash? because i cleared my code took half day for it to come back...imagine changing each coil and waiting for freaking code after clearing to come back....wut u guys think?
Old May 10, 2006 | 06:38 PM
beer boy's Avatar
beer boy
ya it can take a while. but don't wait for the code to come up drive truck and see if there is a difference.
fordguy4life- how did you get to number three? did it through a code or did you try and replace them. its great either way that you found it.
Old May 11, 2006 | 07:14 AM
fordguy4life
Smile
Process of eliminatioin, really....Thanks for the help! I'm really starting to dislike the 'COP' design, though. Soon I'll have all new COPs. Think I only have 3 originals left. Wish I had a spare $500...I would have replaced them all at once.
jamer
1983 - 2012 Ranger & B-Series
Feb 3, 2015 07:26 PM
Rednecktech
Feb 17, 2013 09:42 AM
t1darian
Nov 3, 2011 11:33 PM
chuckster48
2004 - 2008 F150
Mar 8, 2010 08:14 PM
JerryandSue02
1997 - 2003 F150
15
Jan 13, 2006 03:49 PM
