Sponsored by: Real Truck
Alternator Ouptput ??
Old May 5, 2006 | 08:44 AM
Commandohorn's Avatar
Commandohorn
I have a 2001 7.3 PSD F250. What is the output of the alternator? I can't find it in the OM. Thanks!
Old May 5, 2006 | 08:47 AM
02PSD4ME's Avatar
02PSD4ME
IM not complettly sure but I think it is 140 amp for the single and 260 amp for the duel.
Old May 5, 2006 | 09:24 AM
tvsjr's Avatar
tvsjr
Were dual alternators offered in '01? I thought they were single 130A units...
Old May 5, 2006 | 11:43 AM
Commandohorn
Sorry about the spelling of "Output" ... anyway, there is only one alternator for the dual batteries. Can I assume it is a 130 Amp?
Old May 5, 2006 | 11:58 AM
Gunner15a's Avatar
Gunner15a
Question. Can anybody tell me why Ford did NOT see fit to put an amp or volt guage in the 06 6.0L SD? I have Oil Pressure, Fuel, Turbo Temp, Engine Temp, and Turbo Boost guages, but why no Amp or Volt meter? As much as it takes to turn those engines over, I figured that volts or amps would be a must have instrument? Anybody know this one?
Gunner15a
Old May 5, 2006 | 11:59 AM
Gunner15a's Avatar
Gunner15a
Interested in this one myself. My truck is set up the same way. One alternator and two batteries
Gunner15a
Old May 5, 2006 | 01:48 PM
Commandohorn
Just got confirmation from a diesel mechanic. It is a 130 AMP alternator.
Old May 5, 2006 | 04:14 PM
tvsjr's Avatar
tvsjr
Yep, it's going to be in the ballpark of 130A (current-MY PSDs have the option of a 130A "standard" alternator, a 140A "heavy-duty" alternator (presumably more power at idle), and the dual (140A+120A)).
Remember, it's 130A when the engine is spooled up. Assume it's capable of 50% of that at idle (unless you idle the engine up with AIC/SEIC), and subtract the load the truck is already pulling to run its electronics...
Old May 5, 2006 | 04:15 PM
tvsjr's Avatar
tvsjr
Gunner15a
Because they're cheap? And, the oil pressure and trans temp gauges are useless.
The right solution... install your own gauges.
Old May 5, 2006 | 05:45 PM
ryaneverk2's Avatar
ryaneverk2
Gunner15a
In I think 2002?? or so they replaced the voltage gauge with the tranny temp gauge. My 2000 has a voltage gauge, but no tranny temp. Yours has a tranny temp but no voltage.
Old May 5, 2006 | 07:23 PM
Gunner15a's Avatar
Gunner15a
No my 06 PSD has a Turbo Temp. I'm planning on towing a 5th wheel camper trailer with it so I might add an exhaust temp and tranny temp though. I was just wondering why it didn't have an amp or a volt guage
Gunner
Old May 5, 2006 | 09:27 PM
tvsjr's Avatar
tvsjr
Gunner-
I don't think so... Ford's site backs me up. You're talking about the gauge top-right? That's transmission temp. I've never seen a pyro in a 250/350 that wasn't aftermarket.
Old May 5, 2006 | 10:43 PM
Gunner15a's Avatar
Gunner15a
Originally Posted by tvsjr
Gunner-
Huh.......Ok. Thought that was the turbo temp........That just goes to show you how far behind the curve I am on this beast. Reading all I can out here in the Wyoming wilderness, trying to get up to speed
Gunner15a
Bigtom04
Feb 28, 2019 03:16 AM
Country Acres
Nov 28, 2015 06:46 PM
kbarbee95
Jul 9, 2015 03:10 PM
QCIGUY
1978 - 1996 Big Bronco
Jul 27, 2008 12:11 AM
schmidt64
Dec 12, 2007 08:37 AM
