I know this is a common problem but Around Feb. I noticed my truck die a few times on me when at idle. Just recently its started doing it at any speed and at any time. I think it's the CPS but its been doing since Feb. is it common for the CPS to show problems and last another 4 months? I can still drive the truck, if it dies it starts right back up. When and where it dies is totally random; I've gone over a week w/ out it dying then other times it'll die 3 times in a mile. It's an 03 w/ 38000 miles. Since its under warranty I left it w/ ford for over a week showed no codes so they charged me $85 and gave me the truck back. I've already changed the fuel filter. Any ideas? or is it just the CPS? if i change the CPS and use the blue one will it void my warranty?
For $85 you could put one in and know the answer.
Even if it don't fix your problem you have a much needed spare.
IF it fixed the problem, you may be able to get ford to reimbuse you
part cost.
I would second what Hott-Rodd said. Buy the black one off EBAY and if it fixes the problem tell your local Ford stealer to give you your money back and pay for the CPS sensor!
I've already ordered the blue one; Will that matter? will it void the warranty?
I don't know about voiding the warranty, and the debate is stillout there on te blue one, some people love it, some don't. I am planning on a chip from Jody at DP Tuner and he said to stay with the black so that is what I am doing! I have a spare in the glove box.
Did It Fix The Problem?because My 95 7.3 L F350 Doing The Same Thing.ps Dous Anyone Know What That Like Air Valve Is For On Side Of Fuel Filter?
that yellow lever is to drian the fuel out of the filter. turn it and fuel will run out. i suggest hooking a gas line to the end of the factory drain line otherwise you will get diesel everywhere
My new CPS comes in on Monday so I'll let you know. On my motor there's a yellow valve lever that drains the fuels cup Is that what your talking about? Also, I don't think my problem's fuel related because Its been way too long.
I Think Your Right On The Fuel Thing Cus I Did Every Thing And Still Dous What Your Saying.and No On My 95 It Has A Like Tire Valve On The Right Side I Was Wandering What It Was For ?to Bleed The Air Out Of The Can?
Right On Stokin Thats What I Thought And I Think That Will Fix The Dying And Burps.do Yo Bleed When Running?i Think So So I Am Going To Do That In A Min.
