More idling issues...
Old Jun 6, 2006 | 09:49 PM
  #46
Mil1ion's Avatar
Mil1ion
Here you go.
http://www.clubfte.com/users/mil1ion/7_72J_R11.jpg
To have a copy on your computer...right click the image and save it as whatever you want
Old Jun 7, 2006 | 08:13 AM
  #47
1975Ford's Avatar
1975Ford
Check the spark plug firing order and check the cap and rotors.
Old Jun 7, 2006 | 08:37 AM
  #48
tcbofade's Avatar
tcbofade
1975-Plugs are good, cap and rotor are good, firing order is correct. No compression on number six cylinder. With a little luck, I'll find out why this evening. I'll confess I haven't done much with adjusting the idle or timing while chasing down the compression issue.
Dennis-without an id tag, how do I tell if the carb is a 2100 or 2150? With a little luck, it won't matter, but with MY luck....
Old Jun 7, 2006 | 09:07 AM
  #49
jdrone's Avatar
jdrone
When you say no compression you mean zero? or is it low? what kind of compresion do the other cyls. have?
Old Jun 7, 2006 | 09:21 AM
  #50
tcbofade's Avatar
tcbofade
No means none. Cylinders 1,3,4,5,7 and 8 are between 100 and 110 lbs. Cylinder 2 has 60 lbs, and number six has zero.
Old Jun 7, 2006 | 09:22 AM
  #51
tcbofade's Avatar
tcbofade
Pulled the valve cover...both valves appear to be functioning. No visible damage. Had the girl next door turn the engine over with the key, and both valves opened and closed. I'm going to put some compressed air into the cylinder head tonight and see where it goes...
Old Jun 7, 2006 | 09:54 AM
  #52
jdrone's Avatar
jdrone
You could squirt some oil down the cyl and see if that increses the compresion if so sounds like rings. also frist thing to do it make sure the valves are not to tite. they might be moving but if they are not closeing all the way you wont have any compression. also the differnt comprision amounts could be your cause for dieing in gear.
Old Jun 7, 2006 | 10:43 AM
  #53
Mil1ion's Avatar
Mil1ion
The fact that you have that accelerator pump type rod on the front of the carb makes me think it is an older 2100 instead of the 2150.
I'm looking for a pic of the 2100 right now.
Old Jun 7, 2006 | 02:24 PM
  #54
fasthauler's Avatar
fasthauler
I think you have found your problem, Put compressed air into the #2 and #6 spark plug holes and listen for air. You will find the problem by just following the hissing noise. Good luck, Gary
69 f250 cmpr special
Nov 21, 2014 05:04 PM
cryptyx
Sep 29, 2014 08:27 AM
friction
Aug 7, 2013 06:53 PM
79F-1504x4
Apr 20, 2010 05:45 PM
nzabka
28
Jan 30, 2004 05:11 PM
