I need to know if anyone knows where I can find a fuel recirculation module. This part will be going on a '96 Ford F-250 PS. The part sits on the right side of the fuel filter canister. It screws right into the fuel filter canister. I've called a ton of salvages and no one has one of these parts. I am also needing the vaccuum switch that ties into the side of the module. If anyone knows where I can get these parts at a reasonable price it would be greatly appreciated.
are you talking about the fuel pressure regulator? on the drivers side of fuel bowl?
if so check ebay. there was a few guys parting out motors. email them. actually i believe someone from here bought a fuel canister. maybe they dont need the fpr if that is what you need.
sorry i have enver heard of anything called a recirculation module. do you have a pic of the part?
It may be a fuel pressure regulator. The reason I called it a fuel recirculation module is that was what the Ford parts dealer called it. I bet it is a fuel pressure regulator it does sit on the drivers side right by the fuel filter canister.
here read this thread and send a pm to f350 hauler. good guy he should be able to help you out. lets make sure we are talking about the same part first. let me look for a pic.
ok i went and took one hopefully this helps.
