1978 - 1996 Big Bronco
recall
Old May 2, 2006 | 11:42 PM
khadma's Avatar
khadma
Carpenter Local 745
recall
I just got a recall reminder from FoMoCo for my Bronco speed control switch.
I read it is a serious matter.
Anybody have any problems before or after the fix?
khadma
Old May 3, 2006 | 06:21 AM
Streetgang's Avatar
Streetgang
IIRC it had something to do with the cruise control, and how by pressing on the break it turns it off. The switch/harness piece that is on some Broncos at the end of the master cylinder with the two wires coming off it is the culpret...I think???
Old May 3, 2006 | 12:09 PM
b4hntn's Avatar
b4hntn
I replaced it all at my expense many months ago. Cheap insurance. Last week the Ford service manager said bring receipt, they will reinburse me and enter in the computer it has been done. He said "If pressure switch is leaking they replace it and add a fuseable link but if it is not leaking they just add the fuseable link". Brake fluid leaking past a membrane into the switch may start fire. The fuseable link will blow before starting a fire now if the membrane fails. Power is always on through this switch thus the horror stories of burning down homes. IMO newer models are more likely to have the problem but I think everyone should do the recall if you qualify.
Old May 3, 2006 | 02:37 PM
khadma's Avatar
khadma
Carpenter Local 745
Thanks for the info, I was wondering if power is supplied only if the speed control was being used. I guess electricity is always there. I will schedule an appointment asap.
I really do not want to lose my Bronco!
Mahalo
KHADMA
Old May 3, 2006 | 05:06 PM
b4hntn's Avatar
b4hntn
If you think you will lose sleep just disconnect the plug from the switch screwed into the top of the master cylinder. Your speed control will not work but it totally eliminates the possibility of it causing a fire until you can get to the dealer.
Old May 4, 2006 | 11:11 PM
94 XLT White/ Silver 302's Avatar
Mahalo
KHADMA
Power is supplied to the switch all the time. The picture below is the new pressure switch Ford is using, I upgraded the pressure switch myself back when I first herd about the problem. Ford performed the recall yesterday by installing a new wiring harness with a inline fuse going to the pressure switch. I will try to post a picture of the harness with the inline fuse today.
Old May 5, 2006 | 07:34 AM
Picture of the new harness with inline fuse. It's the plug with an (H) on it, and the shinny harness with a blue tag.
Old May 5, 2006 | 03:54 PM
RA81222's Avatar
RA81222
What year does this effect? I have 93'.Bought it second hand and not sure if it was done.
Old May 5, 2006 | 04:50 PM
See next thread.
Old May 5, 2006 | 04:52 PM
This effects 1993-2003 F-series, so if I were your I would give Ford a call.
Old May 5, 2006 | 07:48 PM
Fishallot's Avatar
Fishallot
Thanks for the reminder. After reading this thread I decided to finally call and schedule mine for Monday.
khadma
Hawaii Chapter
358
Sep 18, 2013 12:54 AM
khadma
Jan 3, 2013 08:13 PM
khadma
General Automotive Discussion
Dec 22, 2012 02:08 AM
khadma
1997 - 2003 F150
Jul 1, 2008 12:12 AM
khadma
17
Jan 6, 2008 09:55 PM
