I should be getting my settlement in June, and plan on painting my Bronco blue, installing Performer cam and kit, and truck performer intake, as well as headers and a complete 3 inch exhaust with Magnaflow cat, and muffler. Tru trac for the rear end, 2 new tires, and matching rims, and a major tune up of the engine. Also, since it needs front brake pads, I'll be trying those EBC pads. However, that will most likely happen soon, as it is starting to squeal. Also plan on getting the original leather seats redone. Adding real gauges, and getting that Warn winch with the synthetic rope instead of a cable. My plans are to hide it behind the front license plate, but I don't know if that will be possible. I may or may not get a front brush/push guard for it, I have not made up my mind on that yet.
Bronco - finally going to replace carpet with vinyl flooring from JBG.
Install sub woofer
Fabricate new gas can mount on tire carrier
Possibly fabricate a steel rack inside cargo area
97 Explorer - change rear shackles
Install junk yard spare tire and cable lift
99 Explorer - fix P0171 and P0174 infamous 4.0 intake leak
I have to finish up a home renovation job, the I plan
To get back to building canoe paddles then start building a Hawaiian
Outrigger canoe, possibly using the project as a mentoring tool
For young adults and teens.
I am looking forward to 2013 and it's possibilities.
Install sub woofer
You may have to provide some pictures of the project, those canoes are cool.
For me, my list is too long so I can mentioned some key parts.
78 Bronco "TGM": Fix this coolant issue I am chasing now, fix my rear drum brakes so they work like real brakes should, Find out why my new front brakes are squealing really bad, Find the original style carpeting for the floor in my truck, Get at least the front seat refurbished with matching skin and new foam, a bunch of engine work including a possible full rebuild, other drivetrain work, paint if the truck is ready, and finally.... A job so all of this can be made possible. If there is time I wouldn't mind finding myself a girlfriend but those cost money too so i have to pick the right one .
I have a ton of things I want to do but Those won't get done till the things I need to do are out of the way.
EDIT: Also, khadma, if you need help installing your subs, let me know. I might be of some use there. I don't know too much but installing subs and an amp is pretty easy.
Girlfriend? why would you want a girlfriend? They cost more than a truck! And besides, TGM might get jealous!
Forgot to mention a gas rack addition to my tire carrier. Thanks khadma for reminding me. I also want to find an inside tire carrier, so I can carry two spares instead of one, and not have to resort to putting it on the roof.
Jim
Girls smell nice, way nicer than gear oil and welding fumes.
I haven't decided on using the new type of steel gas can with the filler nozzle
Or a plastic can. I have on old style Blitz can now, I want to get
One that is more user friendly.
Jim, are adding a gas can to a stock outside carrier?
I am sure you can find a stock inside carrier just about anywhere too.
Yes, I want to fabricate a gas can mount that will be on the outside tire carrier. However, I also want to have an inside tire carrier so I can have two spares. I don't want a gas can inside. Not full of fuel anyway.
Looks good. I could live with something like that. Once this new job takes off, I'll sign up for a basic welding course, and learn how to weld so I can make mine.
