Float charger
Old May 2, 2006 | 07:11 PM
srercrcr's Avatar
srercrcr
Float charger
I've been using a 1 amp trickle charger to keep my trucks battery fully charged, since I don't drive it enough.
I see on ebay what are called "float" chargers.
Do they somehow cut off charging when battery is fully charged?
Worthwhile?
Thanks.
Old May 2, 2006 | 08:35 PM
Franklin2's Avatar
Franklin2
They almost do. They still monitor the battery and keep it topped off. Some are more sophisticated than others. You pretty much get what you pay for like everything else.
Old May 10, 2006 | 07:40 PM
Kajtek1's Avatar
Kajtek1
The float means they go to preset voltage (usually 13.5V) and maintain it.
Trickle and regular charger can go as high as 18V eventually boiling dry the battery.
http://www.harborfreight.com/cpi/cta...emnumber=42292
I've been using those for years, what saved me lot of money on replacing the batteries every season on my toys. Even it says the limit is one mid-sized battery per charger, I had it hooked up to dual battery bank in my motorhome whole winter.
Old May 10, 2006 | 11:07 PM
lsrx101's Avatar
lsrx101
I was told many years ago by an instructor in a"battery class" that the best way to store a "good" lead-acid battery is to fully charge it and store it in a deep freezer. It supposedly slows down the chemical reaction. I tried this with a garden tractor battery for 4 years. It seemed to work. I used to get 2 years from a battery, With the deep freeze I got four. It failed late in the season on it's 5th year after purchase. You need to let it set and come up to ambient before using it. I've never had the chance to try this with an automotive battery.
omni
Electrical Systems/Wiring
Nov 18, 2014 05:28 PM
Banage
General Diesel Discussion
Oct 30, 2013 06:26 PM
bigtexan99
Jan 11, 2009 11:36 PM
danlee
Dec 26, 2007 09:21 PM
Nevada Max
Aug 22, 2007 04:35 PM
