Should I get a float charger?
I work >1 mile from work. Yes, I drive there in the winter it can get -45f I read one place the batts wont charge fully with short driving/warm up time. What do you think of a float charger for my situation?
P.S. To my understanding, float chargers turn off when fully charged, that's why I chose it
Received 3,101 Likes
on
i use solar panel chargers like this one: 1.5 Watt Solar Battery Charger
they keep the battery topped off.
on
plug it into the cigarette lighter and forget about it.
a 60 watt light bulb will produce enough light to produce 12 volts, so even if you park in a garage the light coming in through a window is enough.
and they will produce power with 4-5 inches of snow on the windows/vehicle.
at 1.5 watts, there is no need to worry about overcharging, that is equal to a little over what the radio and computer memory uses.
and it has a back-flow preventer so it will not back-flow power to the solar cells and drain the battery when there is no light
A battery tender or any of the modern intelligent battery chargers is a decent idea for overnights at home. Very few chargers are built without overcharge circuitry anymore.
I had a car that had a parasitic draw if left for more than 48 hours in the winter. I hooked up a battery tender and just plugged it in whenever I parked it.
I assume you also have a block heater? I think that should be standard in your area, but I have heard that aren't in all parts of the USofA, so I thought I'd check. Helps a lot with the cold starts.
Around here CAA (our version of AAA) sells battery tenders for pretty cheap, so something to check out if you are a member.
rtcalabrojr
28
02-14-2010 08:08 AM
