I got new pads for the front from Kragen. I have the two piston dayton calipers on a d44. At kragen, they asked if I have two piston calipers and I said yes.
The pads wont fit over the rotor.
Are there different size rotors used with the two piston calipers? Mine are 1.25" wide and the distance between the pads when loaded in the caliper is about 1.125"
The last pads I bought were also quite thick. I compressed the crap out of my pistons to squeeze those bad boys in! But they did eventually go. Heavy duty C clamp, not the 'HELP' section pad compressor. (that does work well, but I found it only works on cars... Then there are the cars like the Lincoln Continental which have pistons you 'screw' back into place using a special spanner tool)
