Off the top of my head, you need the grille itself, headlight buckets, headlight doors, and parking light assemblies. All of those are shown in the picture above. The headlights themselves will transfer over.
only a note to add. Some of the grille holes are in a different location on the 72 fenders and the 67 grille. Most of the holes should match up however there are a few holes along the front of the 72 fender and the 67 grill that will be a few inches off. Ford over-engineered the mountings and there should be plenty of matching bolt holes to make it a sucessfull mount.
Okay, I see what you are trying to do... But what about going the other way like.... 71-72 grill on a 67? Do they match up? I'm not to fond of the look of the 67 grill and like the looks of the 72 grill.
I put a 69-67 grill on my 70 theres two bolts that dont match,
need to use the 69 blinkers cause there part of the grill,
the 70-72 had blinkers mounted to something else,the
light buckets swap since i have one from 69 on one side
70 on other side,though the pieces that cover the light
assembly must be from the earlier grill as the 70's covers
dont quite cover the job,,what else.... the bolts in
the fenders put up a good fight, it's a bolt off, bolt
on job no tricks.earlier grills look better I think
For anyone who prefers the 70-72 grills to the 67-69, I have a 1970 grill in great shape that I'd trade for a 67-69 grill in great shape. Just throughing that out there. I can be e-mailed at batman_josh(No Email Addresses In Posts!) Thanks.
