Offroad & 4x4
NP205 not shifting...
Old May 1, 2006 | 04:44 PM
RawPower's Avatar
RawPower
Hey I just got a Div NP205 and so Im rebuilding it, but it didnt really need it. Bearings are all tight and have zero excessive play in them. The gears do not have a wear patern on them at all. The only signs of usage are on the gear collars that move back and forth over the gears from when engaging. So basically Im just cleaning it up and fixing all the leaks.
The front output shaft/gear assembly is working fine. The shifter fork moves freely, doesnt take a lot of force to get it to engage.
BUT.
The rear output gear assembly, however, wont shift very well. It goes from 2HI (furthest back position) to (center) but will not go forwards again. So I thought maybe the shifter bearing thingy that holds the shifter rail in HI, N, or LOW for the rear output might be too tight. So I took it out, to no avail. So then I took out the shifter collar to see if it would work, which it still didnt.
Also, the gear collar isnt in contact with the front input shaft gear. The rear shaft/gear of the Input / Rear Output assembly is not installed at the moment.
I used a hammer to try to engage it, but no worky.
Thanks for yalls help.
Old May 1, 2006 | 06:38 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
did it work before you tore it down?
Old May 1, 2006 | 07:03 PM
RawPower's Avatar
RawPower
Yeah kinda... still not very easily though. Had to use hte back of a hammer to yank on the shifter rod connector.
Old May 1, 2006 | 08:56 PM
chrono4's Avatar
chrono4
a perfect example of what my mom always used to say about me, " it worked until you messed with it"
Old May 1, 2006 | 09:53 PM
RawPower's Avatar
RawPower
Haha, yeah... Oh well. At least I know my t-case inside and out now. Or sorta. I guess if I knew it inside and out I could fix this problem.
Old May 2, 2006 | 08:48 AM
fishmanndotcom's Avatar
fishmanndotcom
did you use a bigger hammer?
-cutts-
Old May 2, 2006 | 11:26 AM
KubotaOrange76
weld it up
Old May 2, 2006 | 02:14 PM
fordraceboy's Avatar
fordraceboy
my daddy always told me to never screw with a piece of iron if you got a torch and a welder. i don't see a problem here, unless of course you don't have these pre-recquisite tools. and then the only problem is that it's time to go shopping baby!!! sears here i come..... LOL
Old May 2, 2006 | 02:24 PM
RawPower's Avatar
RawPower
well your daddy doesnt make much sense to me... but anyways, I have the so called "pre requisite" tools, better way to say that is mandatory... but I didnt get why they are mandatory... anways- Why am I going to sears?
KO, Weld what up?
Old May 2, 2006 | 02:53 PM
KubotaOrange76
just weld it up....its a good motto to live by
Old May 2, 2006 | 03:46 PM
fordraceboy
nevermind....
Old May 2, 2006 | 04:45 PM
RawPower's Avatar
RawPower
Im lost...
Old May 2, 2006 | 05:00 PM
KubotaOrange76
go to mapquest.com
BigShelby
Aug 14, 2016 06:13 AM
Midnight Garage
Aug 9, 2016 04:59 PM
Craigwell
15
Sep 10, 2014 09:53 AM
swooshcmk
Aug 3, 2012 01:08 PM
