'95 AODE, no third gear
Old May 1, 2006 | 12:57 PM
minnesota4x4's Avatar
minnesota4x4
I just finished my 302 to 351w swap, and because the tranny worked great before the engine swap I reused my existing AODE installed a B&M shift kit. I'm also reusing the 302 wiring harnesses and ECU. When I put the truck in "D"rive it starts out in 2nd and will not shift unless I run the RPM's over 3000 and let off the gas then it's like it's in neutral, no go. I can manually put it in "1" and "2" and they work fine. So I pulled the AODE out and figured it was time for a rebuild, the AODE had 104k on it. After the rebuild I put the tranny back in the truck and it's doing the same thing, no 3rd gear. The guy that rebuilt the tranny thinks it's probably electrical and suggested replacing the 1-2 solenoids. Any other ideas????? Thanks
Old May 20, 2006 | 12:47 PM
amish77's Avatar
amish77
check the connections, but I think he's right.
Reed
44
Oct 13, 2012 08:24 AM
Unionite
Aug 18, 2011 11:34 PM
thebigyetti
Aug 4, 2011 09:50 AM
niteowl
22
Aug 12, 2005 10:03 PM
makemeknowit
Sep 29, 2003 09:36 AM
