Aerostar Ford Aerostar
Upper Control Arm thud and pop
Old May 1, 2006 | 09:02 AM
jhjandal's Avatar
jhjandal
Angry Upper Control Arm thud and pop
After replacing all both upper control arm bushings and ball joints myself, I am having a problem on with thud/pop noise that I can't figure out. It is only happening on one side (the driver side) and not the other. I did the same thing on both side. The noise comes on when I backup or when I go forward from backing up and when I apply my breaks a little hard. I thought it was the ball joint, but that is not it because I replaced the one I got from AutoZone with one from PepBoys that looked a little different.
Thank you all in advance for your suggestions.
Old May 1, 2006 | 04:02 PM
Mormakil's Avatar
Mormakil
Check your motor mounts.
M
Old May 4, 2006 | 11:01 AM
maxwgn's Avatar
maxwgn
Possible causes - LOWER balljoint, LOWER control arm bushing, wheel bearings, or the bolts you did just didn't get torqued right- try retorquing them first...
Old May 4, 2006 | 11:42 AM
96_4wdr's Avatar
96_4wdr
did you have the "POP" before replacing bushings and ball joints?
Old May 4, 2006 | 01:10 PM
jhjandal's Avatar
jhjandal
Thanks for the insight, I will retorque the bolts again and will inspect the lower ball joint as well this weekend. QUESTION: Since I took the van for wheel alignment afterward could they have loosened those bolts? Can they do alignment without loosening them?
No, I did not have that noise before replacing ball joint and the upper control arm bushings.
Old May 4, 2006 | 02:35 PM
aerocolorado's Avatar
aerocolorado
Sway bar links can move around if not tightened properly. Disc brake caliper torqued down properly?
Old May 4, 2006 | 07:46 PM
96_4wdr's Avatar
96_4wdr
yes, alignment techs can get interupted and leave a tie rod clamp bolt loose or an upper control arm adjusting bolt loose
if you find one loose, take rig back to shop and demand an alignment recheck, safety issue
loose tie rod clamp bolts can strip rod adjustment threads
Old May 4, 2006 | 09:08 PM
cbr900's Avatar
cbr900
hi check your propshaft bearings, back and front.
Old May 5, 2006 | 10:23 AM
jhjandal's Avatar
jhjandal
96_4WDR,
Thank you. It was the upper control arm bolts, they were very loose. I tightened them and now the noise is gone!
Do you think it was the alignment technician's fault that they were loose? I tightened all three bolts.
Old May 5, 2006 | 11:46 AM
copper_90680's Avatar
copper_90680
Originally Posted by jhjandal
96_4WDR,
No, I don't think they would loosen those for the alignment. But that means you need to have the alignment redone!!!!
Old May 5, 2006 | 02:18 PM
96_4wdr's Avatar
96_4wdr
which bolts?
the 2 horizontal nuts that tighten the horizontal upper control arms to the control arm shaft mounted in the bushings? these hold in the camber adjusting shims, comes from factory with a 2mm and a 6mm shim at the forward arm and rear arm
or the large long bolts holding the upper control arm mounts to the frame?
Old May 6, 2006 | 09:07 AM
jhjandal's Avatar
jhjandal
The long bolts that fasten to the frame.
Old May 8, 2006 | 11:27 AM
jhjandal's Avatar
jhjandal
Final solution -- impact wrench
I finally had to have it fixed after the bolts kept getting loose. I would tighten them by hand as hard as I can with the bead breaker and they would still loosen up after a little bit of driving. I took it to the shop where they told me the only way to tighten those bolts permamently where they don't keep getting loose is by using the impact wrench. The did that plus another alignment which cost me $110. Still, I am happy I did it myself. I figured I still saved about five hundred dollars considering the ball joint replacement.
Oh by the way, the van drives beautifully now.
AGrayson84
Oct 24, 2016 10:21 AM
99 ford 2 wheeler
1997 - 2003 F150
Jun 15, 2015 05:06 PM
T.9.X
13
Mar 5, 2011 06:28 PM
Dead Meat
Oct 12, 2010 07:52 PM
jhurd12
Jul 16, 2008 02:48 PM
