First Diesel. Tips??
Old May 3, 2006 | 07:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I hate waiting.......are we there yet?
I am going to go out and pick rocks since we have to wait so long....
Old May 4, 2006 | 12:28 AM
JayH's Avatar
JayH
Okay....here's another....how about a air filter? Is it a good idea to upgrade that deal?
BTW, picking rocks sucks.....how about digging a ditch instead?
Old May 4, 2006 | 09:09 AM
AndysFords's Avatar
AndysFords
Originally Posted by Dave Sponaugle
235/85-16 tires with 4.10 gears and a ZF 5 in overdrive should be doing 47.35 MPH at 1600 RPM.
Different tire manufacturers and tread styles will vary the speed as much as plus or minus 4 MPH.
Yes this is right, but the Speedo will still say whatever it would be with original tires.
Old May 4, 2006 | 11:59 AM
matts156's Avatar
matts156
Thoughts about turbo upgrade
I thought about adding a turbo to my 1993 7.3L. However, it has 239,000 miles on it. It doesn't smoke or burn oil and runs fine, but with that many miles on it, isn't there a good chance that I'll blow a head gasket or maybe even blow out the compression rings? In my experience with gas engines, rebuilding cylinder heads on worn engines often caused problems with compression rings that couldn't withstand the increased compression from the new heads. With the increased compression from the turbo, I would think diesels wouldn't be exempt from that issue. Any thoughts?
Old May 7, 2006 | 09:05 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
MATTS 156 I would leave well enough alone. If it runs good and does what you want. Why ask for trouble ( could be expensive)
Old May 27, 2008 | 11:31 PM
S.P.'s Avatar
S.P.
Talking put a TURBO ON IT!!!!!!!!
If you turbo it you will love it.... I drove a '64 Nova w/a BUILT 283ci. 14.13 at 124mph in the 1/4.....................Now this truck dont have that much scat, BUT...it does have a LOT of power for the wheight........just my $0.02...
Old May 27, 2008 | 11:35 PM
S.P.'s Avatar
S.P.
AND..20+ mpg at 65-70mph....
Old May 27, 2008 | 11:42 PM
S.P.'s Avatar
S.P.
WOW!! let see to much beer, + getting up to pee,+ kids useing the computer,+ me thiking I knew whear I was = embaresment!!!! sorry.
Old May 28, 2008 | 12:40 AM
ljutic ss's Avatar
ljutic ss
S.P. are you sure about the 124 mph in the 1/4 ?
Old May 28, 2008 | 11:33 PM
S.P.'s Avatar
S.P.
Exclamation 124mph 1/4 mile
Yes 124mph in the 1/4....that day my best time and my fastest where not on the pass...
Old May 29, 2008 | 11:02 PM
JoSHN's Avatar
JoSHN
JayH, Welcome to FTE and the IDI diesel forum.
A good power upgrade is a turbo.
You can do small improvements with exhaust and intake mods, timing and fuel mods.
But a turbo is the biggest bang for the buck.
Yes, a turbo will put you right up with the first generation Power Strokes for both torque and HP. 1999 is when they went over 235 horse if I remember right.
Check the coolant for SCA's (Supplimental Coolant Addaive) test strips are available at NAPA. This addative goes in the coolant to prevent cavitiation.
So here is my issue. I just bought my truck, I'm still fixing a few other parts, while paying insanely high rent, astronomical food prices, and almost $1.40 per litre for diesel.
Needless to say, I don't have the extra money lying around for a turbo.
So, why kind of exhaust system would anyone suggest?
And for the intake, am I looking at a K&N filter, or is there an actual air intake that I can buy?
Old May 30, 2008 | 09:03 PM
Dave Sponaugle
On a NA motor, changing the exhaust pipe to 3" pipe helps let the engine breathe.
Any good exhaust shop should be able to fix you up.
They need to start with the 3" pipe up in the Y pipe, so each downpipe from the manifolds dump into the 3" pipe.
Good free flowing muffler and you are good to go.
What many of us has done is make your own ram air intake that can get cooler air from in front of the radiator.
I know that is an easier job on the older models, but it can be done on the newer ones as well.
There are no aftermarket kits I am aware of, everyone has forgotten the IDI motor.
Old May 31, 2008 | 02:15 AM
  #28
JoSHN's Avatar
JoSHN
Well, I do have a birthday coming up, So I'll probably be getting that exhaust for my gift.
And as nice as it would be to have a cold air intake, Stove pipes and hose clamps just won't do it for me.
I guess I'll settle with a K&N filter.
Old May 31, 2008 | 11:48 AM
  #29
Dave Sponaugle
No stove pipes or hose clamps, I used a left over furnace plenum side metal to make the scoop.
Then a section of 6" duct work to make the rectangular to round transition.
Followed by a 6" x 4" duct reducer and a single wall 4" adjustable ell.
The stock flex duct slides over the ell and onto the air box intake.
Yes I have done HVAC work in the past, so I do have a lot of metal working tools.
All fastening was done with either screws or pop rivits.
Old May 31, 2008 | 02:00 PM
  #30
JoSHN's Avatar
JoSHN
I'm looking at the actual box the filter sits in on yours.
Where did you get it, and how did you mount that?
If I can get mine to look similar, or atleast have that type of setup, I wouldn't mind doing that at all.
I just do not like my stock unit. In fact....I loathe it.
Diesel drinker
Nov 26, 2014 08:18 AM
Rockaholic
52
Jan 22, 2012 09:51 PM
gilend
Car/truck Buying Advice
Jul 17, 2011 06:01 PM
scrapperdan
Jan 7, 2006 10:12 PM
