Engine shutting off
Old Apr 30, 2006 | 07:18 PM
1ford1's Avatar
1ford1
Engine shutting off
Hello fellow Ford people. I have just purchased a 1975 F150 to add to my collection. The previous owner has butchered the wiring. The motor is a built 460 (with DOVE C heads). The cam is extremely radical, but I have got it to idle somewhat. The problem now is that it shuts off after running for 3 to 5 minutes, then is hard to start again. Sometimes it will not do anything. The alt light is on and goes out when you try to engage the starter then comes back on. The lights do not dim when trying to start. I was thinking that it may be the ignition switch. Any suggestions?
Old Apr 30, 2006 | 07:22 PM
LxMan1's Avatar
LxMan1
Could be a wiring problem if it has been butchered. You need to check for 12V to the S terminal on the solenoid when you turn the key.
Have you checked the voltage at the battery when it is running? It should be above 13V. It could have a bad ignition module that would make it die when it is running.
Old Apr 30, 2006 | 07:36 PM
1ford1's Avatar
1ford1
Thanks for the reply. The battery voltage seems to be good. I have also noticed that the engine will not try to fire as I am trying to start it but will try as I release the key while attempting to start. Also , I did a compression check and all cylinders came up between 185 and 190 except for number 3. It came up at 240, I tried it three times. Any ideas on that?
Old Apr 30, 2006 | 08:27 PM
F1rocco-NY's Avatar
F1rocco-NY
Too much timing...Heated starter........Ignition switch.......Grounded/burned starter wire on exhaust...Thats what I would check.......
Old Apr 30, 2006 | 09:00 PM
Craigster1's Avatar
Craigster1
Originally Posted by 1ford1
will try as I release the key while attempting to start. ?
My guess, ignition switch. Bad contact at start position, good contact at run pos. Easy check.
With the key in the run position do you have power at the coil and if so what is the voltage?
With the cable to the starter removed and the key in the start position, do you have power at the coil and if so what is the voltage?
<O</O
Old May 1, 2006 | 01:41 AM
Mil1ion's Avatar
Mil1ion
Possible Over-heating coil.
12 volts of ignition during engine running... time & time again will toast a coil.
Old May 1, 2006 | 11:07 AM
KJKozak2's Avatar
KJKozak2
F1-rocco is right on the money.
I had similar problems with my 460. The first part of my problem was that the starter was getting cooked (typical with a 460 transplant in a 4x4) so I made a heat shield. Second was the starter solenoid to fix the 'starting when you let the key go' thing. Next I replaced the whimpy battery cables with some meaty ones. These things solved 80% of the problem, but it still started hard when hot. Setting the proper timing did the trick and I haven't had a problem since.
K.
Old May 1, 2006 | 11:30 AM
Mil1ion's Avatar
Mil1ion
My reply was directed to why the engine shuts down after 3-4 minutes on its own
Old May 1, 2006 | 12:27 PM
Craigster1's Avatar
Craigster1
I agree with Dennis, its sounds to me like you may have than one problem here.
In addition to those things already mentioned, the problem re; starter not turning over could be the simplest thing like corroded or broken batt connections/cables, .
Old May 1, 2006 | 01:41 PM
Mil1ion's Avatar
Mil1ion
A Non-start condition on a hot engine is a common problem with Ford PU's.
It is even worse on a truck with headers.
2011F-250KR
6.7L Power Stroke Diesel
Feb 25, 2015 10:13 PM
carl2591
Jan 25, 2015 10:07 PM
LucasMN
1997 - 2003 F150
Oct 12, 2012 10:36 AM
wes harmon
20
Jun 13, 2011 04:00 PM
Crabby144
Apr 14, 2010 12:18 PM
