Oil Change Frequency?
Old Apr 30, 2006 | 11:45 AM
fcfirefighter05's Avatar
fcfirefighter05
Just looking for some input on how often to change the oil in theses 7.3s.
I have a 01 F250 4x4 6sp man and do mostly nuthin but easy road driving.
Thanks
Old Apr 30, 2006 | 12:22 PM
fordff's Avatar
fordff
I change every 5000, and I know some that change every 3. Cheap insurance.
Where is fc?
Old Apr 30, 2006 | 12:44 PM
clux's Avatar
clux
Depends; if you are still under warranty coverage and want to keep it, change at the interval reccomended in the manual.
I run 8,500 to 9,000 mile interval.
International reccomends 10,000 to 12,000 mile interval for the 7.3.
Old Apr 30, 2006 | 12:58 PM
fcfirefighter05
so you're saying international says you can go for 10,000 miles before changing the oil?
FC is in GA south of ATL
Old Apr 30, 2006 | 01:04 PM
clux's Avatar
clux
Yes, that is their reccomeded interval for the 7.3 in other applications (school buses and medium trucks).
Old Apr 30, 2006 | 01:08 PM
nodakford's Avatar
nodakford
I use Rotella 15W-40 and change 5k, as per Ford manual. The diesel shop here said the reason 5k with a PSD is 1 it is good to have clean oil for the injectors, and 2 the anti-foaming properties it start to break down.
Old Apr 30, 2006 | 01:11 PM
fcfirefighter05
ok, I appreciate the info. I had planned on doing every 5k and using the Rotella 15w-40 but wasn't sure if I needed to do it every 3...it also has 160,000k mi on the engine. I also plan on doing the fuel filter every 10k...unless someone knows different. Thanks
Old Apr 30, 2006 | 01:19 PM
clux's Avatar
clux
Cool, but that is not what International, who build and warranty the engine claim:
http://www.internationaldelivers.com...444edetail.asp
10,000 miles, 350 hours.
My opinion is that the 5,000 mile interval is a device of the dealer to get you in their shop more often, so they can try to sell you other stuff.
And that's just my opinion.
Old Apr 30, 2006 | 01:29 PM
hink10's Avatar
hink10
IMHO, if you do any more than 5k, I would have an oil analysis done just to be safe. Also depends on driving conditions, dust towing driving style etc..
Old Apr 30, 2006 | 01:43 PM
clux's Avatar
clux
It's a good idea to do an UOA occasionally, you can learn a lot about your engine.
Given the choice of 5,000 interval without any UOA or 10,000 with an UOA every change, ............well I guess it's obvious which one I would pick.
Here's something that was posted here years ago, makes me laugh every time I read it:
The 3,000-mile or 3-month oil change has long been the standard in the United States, and has served Americans well. Over the last decade, however, there has been a gradual shift away from this traditional oil change interval. But maintaining a 3,000-mile or 3-month schedule is cheap insurance and many motorists would do well to retain it. Let's answer some questions about this robust maintenance regimen.
Q: How often should I change my oil?
A: Every three months or 3,000 miles, whichever comes first. It's cheap insurance.
Q: Do you actually know anybody who drives less than 3,000 miles in three months?
A: One guy. He drives about 200 miles a month, and takes the public transit system the rest of the time.
Q: So this guy should change his oil, even though it only has 600 miles on it?
A: You never know what could have happened to the oil while it was just sitting there. It's cheap insurance.
Q: At 200 miles a month, wouldn't it be cheaper to just rent a car?
A: We're getting off topic here.
Q: My owner's manual doesn't say anything about 3,000-mile oil changes. It says to go longer than that.
A: Car manufacturers are in the business of selling cars, and they believe if they can make your engine wear out prematurely, you'll go back to them for another car. The 3,000-mile interval is cheap insurance against this.
Q: Well, the car has an oil life monitor that tells me when to change the oil. Can't I go by that?
A: How can the car possibly know what's going on in the oil? They make those things go too long for the same reason they print inflated numbers in the owner's manual.
Q: Actually, I think they use a complex mathematical model tailored to the specific engine and oil type, which uses input from the variables measured by the engine computer such as RPM and operating temperature.
A: And you TRUST them?
Q: But if the engine fails prematurely, doesn't the manufacturer eat the cost of repairs during the warranty period?
A: Oh but it won't fail until the car is outside the warranty period.
Q: So how is that a premature failure?
A: It won't be TOO far outside the warranty period, you can be sure of that.
Q: Okay, so car manufacturers carefully craft their oil recommendations specifically so that the engine fails after the warranty period so they don't have to pay for it, but not too far after the warranty period so consumers will come back to them for another car, instead of buying from a competitor that doesn't yank them around like this?
A: They ALL do it. And the 3,000-mile interval is cheap insurance against it.
Q: You're saying that if your engine blows up with 60,000 miles on it, you'll go back to the same manufacturer for another car?
A: My engine will never blow up, because I'm using a 3,000-mile interval.
Q: Can I switch to synthetic oil?
A: Sure. Synthetics offer many technological advances, including superior viscosity stability, better extreme-temperature performance, higher levels of acid neutralization ability, more shear strength, improved film cling, and of course slight improvements in fuel economy and horsepower in some engines. Great stuff, synthetics.
Q: So how often should I change the synthetic oil?
A: Every three months or 3,000 miles. Even with synthetics, it's cheap insurance.
Q: Um, the stuff costs two to three times what conventional oil costs. That's cheap insurance?
A: Compared to how much it would cost to buy an engine, it's cheap.
Q: What evidence is there to show that running extended drains on synthetic oil will cause the engine to fail?
A: I don't have any, because I've never had an engine fail, because I change the oil every 3,000 miles. Now that's what I call cheap insurance!
Q: Uncountable studies performed by auto manufacturers, oil producers, industry analysts, and research groups like the SAE, both here and in Europe, have shown that synthetic oil can hold up for extended drain intervals. Why shouldn't I have some faith in this body of evidence?
A: You don't see anything on the bottle about extended drains, do you? They all say to follow manufacturer recommendations.
Q: You don't think that has anything to do with the litigous attitude in the U.S., and the oil companies' efforts to cover their butts from every idiot who runs his oil-burning 1986 Dodge Caravan completely dry?
A: What?
Q: Never mind. Amsoil says right on the bottle that you can run extended intervals.
A: And you TRUST them??
Q: Er, I thought you said--
A: Best to stick with 3,000-mile intervals. Cheap insurance.
Q: Isn't it wasteful to get rid of perfectly good synthetic oil at 3,000 miles?
A: There's plenty of oil to be had, and it's cheap insurance.
Q: There's plenty of beer to be had, but you don't drink half the bottle and pour the rest down the drain.
A: Oil isn't beer.
Q: Here's a hypothetical question. Each year, Americans consume 640 million gallons of motor oil. Even if we just went from your 3,000-mile interval to a 5,000-mile interval, that'd save 256 million gallons of oil. Most estimates for oil recycling peg the amount of recycled motor oil at no better than half, so even with the most generous estimate we'd still save 128 million gallons of oil pollution. In other words, if everyone increased their oil change interval by 2,000 miles, we'd save the nation the equivalent of 13 Exxon Valdez accidents each year. Isn't that a worthwhile goal?
A: MY oil gets recycled.
Q: That's not the point. If you use a quality oil, it seems like you could extend your drain intervals by a little bit, helping to reduce pollution and lower your operating costs at the same time.
A: I've never lost an engine using the 3,000-mile interval.
Q: You've never lost an engine using a 5,000-mile interval either.
A: Look, it's just cheap insurance.
Q: Do you wear a helmet in the shower? After all, there are over 110,000 bathtub and shower injuries per year. At 30 bucks, a helmet would be cheap insurance.
A:
Q: Hello?
A: Go away.
Old Apr 30, 2006 | 02:34 PM
cwt580's Avatar
cwt580
i just changed mine for the first time at 4800. it looked thin and really nasty. did alot of winter driving(long idles and warmups) and 1 long 1200 mountain run trip. runs so much better on fresh oil!!!!
Old Apr 30, 2006 | 10:15 PM
Kwikkordead's Avatar
Kwikkordead
Clux, that's hilarious. I'm going to print that out and hang it on the shop wall for customers to read.
Old May 1, 2006 | 01:27 PM
Medic 66's Avatar
Medic 66
I switched to the 5w40 and after about 4000 miles, mileage has dropped off....
Old May 1, 2006 | 01:31 PM
empiretc's Avatar
empiretc
i do rotella 15-40 every 5k and change the fuel filter every 10k. 6637 filter has gone 15k and I am thinking about changing it.
Old May 1, 2006 | 11:02 PM
MRBASS's Avatar
MRBASS
Actually IH does say 10,000 mile oil changes, but that is with a 18qt system, not 14qts like the ford version. IH also Governs their 444e at 2600rpm. if Ford would have used the same version as IH does,and used their fuel system,oil capacity and HP rating and etc, we would see alot more 750,000+ mile powerstrokes.
No way would I drive my Powerstroke 10,000 miles between changes,But thats just me.Even with the 5w40 Syn i run it never gets past the 5000 mile mark.
