Brake Booster Help
Old Apr 30, 2006 | 09:31 AM
51dueller's Avatar
51dueller
Brake Booster Help
Now I'm wondering what type of brake booster would I need for 12 9/16" front disc with 2 piston calipers and 12x3" rear drums? I'm mounting it under the floor and I'm going to use the stock pedal assembly. I can only fit a 7" booster but do I get a single or dual diaphram booster? The donor truck used a 10" booster. I want firm brakes but I don't want them to be very sensitive.
Old Apr 30, 2006 | 09:42 AM
oldjeep's Avatar
oldjeep
Here's one option:
Stock C30 Hydroboost and master cylinder fits pretty well. Requires modifications to the stock brackets and a power steering pump capable of driving it.
Old May 1, 2006 | 01:13 AM
Col Flashman's Avatar
Col Flashman
Use a Midland, it's what was on the F-100s as an Option, as the Hydrovac was on the F-250s & up.
Old May 1, 2006 | 08:55 AM
51dueller's Avatar
51dueller
I'm going to be using a new master cylinder that came originally from the donor truck. I can get 3 aftermarket boosters for it, a 7", 7" dual diaphram and a 8" dual diaphram. The 8" is too big so I'm wondering if I'll have enough pressure with a 7" single diaphram booster?
Old May 1, 2006 | 01:29 PM
Col Flashman
As I recollect, that's the size that originally came as the option.
mikec53
Feb 14, 2017 07:53 PM
Mikulh
Dec 27, 2016 09:04 AM
rvpuller
6.2L V8
Nov 13, 2016 05:23 AM
Joey Fletcher
Aug 2, 2016 02:59 PM
scott79
16
May 18, 2015 04:28 PM
