C6 Transmission filter
Old Apr 29, 2006 | 01:17 PM
Wolfdog's Avatar
Wolfdog
Hi,
In my 1988 F-150 5.8L I have an C6. Just bought the truck. Now the truck is about 1400miles from where I live at my parents place. Parents are too old to check any codes (except I have the VIN)...
So does anybody know what is the filter for the C6 tranny? Any spare part numbers like for AC Delco?
I know this sounds a bit complicated...life is not always simple..
Thanks for help
Old Apr 30, 2006 | 12:13 AM
FSC's Avatar
FSC
The filter is a screen inside the transmission pan, drop the pan, change the filter, reinstall the pan, add about 4 quarts of ATF and your'e done.
The transmission is non-electronic so there are no codes to be had.
Any auto parts store should have a filter kit. (gasket & filter)
Old Apr 30, 2006 | 09:30 AM
Eric C.'s Avatar
Eric C.
Like FSC says any auto parts store will have a filter and pan gasket set for it. A C-6 is a C-6. Just give em the normal details for any part. No problems.
Old Apr 30, 2006 | 11:56 AM
Wolfdog's Avatar
Wolfdog
Thanks
Old Apr 30, 2006 | 12:49 PM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum.
Old Apr 30, 2006 | 02:47 PM
pbear6969's Avatar
pbear6969
Why does the C6 only have a small screen instead of a real filter like other tranny's? I think the kit at Napa is only like 5 bucks and comes with the metal screen and gasket. Sounds like a waste unless you have problems or are tearing the trans apart anyway.
just my 2 cents
Old Apr 30, 2006 | 06:49 PM
rclarke's Avatar
rclarke
If a C6 needs the screen (filter) changed because its plugged the transmission needs to be overhauled. Washing the screen in solvent or thinner will suffice.
Old Apr 30, 2006 | 07:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Use this external filter:
Wix Transmission/PS Filter
Wix transmission/PS filter #58964
Ford equivalent filter kit #XC3Z-7B155-AA
Ford filter alone #XC3P-7B155-BA
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
Old May 1, 2006 | 09:10 AM
Wolfdog's Avatar
Wolfdog
Thanks for advice.
Vadis
361
Jun 13, 2021 03:49 AM
Yaga1973
20
May 28, 2016 10:34 AM
Ordnance
Jul 9, 2014 11:49 AM
87 F-150 I6
15
Jun 26, 2009 11:22 PM
RoyalFord
Dec 11, 2007 09:41 PM
