Sponsored by: Auxito
Power Window Motor Replacement
Old Apr 29, 2006 | 10:50 AM
OldBlue66's Avatar
OldBlue66
What do I need to do to replace the drivers side window motor in my 97 f150? Do you need special tools? or just pull the panel loose from the door replace and motor and push the panel back on. Or is there plastic clips that are going to break off?
Thanks Earl
Old Apr 29, 2006 | 11:53 AM
jrlowscot's Avatar
jrlowscot
To get the door anel off is pretty easy. Pull the plastic pieces off just above the door panel around the window frame. Under you should see 2 black push pins. Push on the center untill it clicks then pull them out. Then remove the cover and un bolt the door handle. Then lift the door panel up and it should come right out, be sure to disconnect the power buttons and the light, not sure but in some Fords the motor is riveted in. If so drill the rivets out and replace with 1/4 20 bolts or something simmilar.
Old Apr 29, 2006 | 01:00 PM
OldBlue66's Avatar
OldBlue66
Thank you I will let you know how it went.
Old Apr 29, 2006 | 06:12 PM
OldBlue66's Avatar
OldBlue66
Thanks motor is in. had to drill out rivets. I did not get the bolts in the motor part just the four other ones. but was very suprised how easy the door panel came off .
thanks agian Earl
Old Sep 22, 2006 | 11:15 AM
hugger94's Avatar
hugger94
I have a 97 F150 with power windows at 193,000 miles. I am glad to hear that removing the driver door panel was easy. I figure that I will be replacing my window motor(s) on both sides. Yesterday morning when I tried to put my order in on the drive-thru, the driver window didn't go down... just clicked under the dash.
I fiddled with the power mirror switch checking to see if it was working and then tried the driver window again. It starting working again but I quickly raised the window again because it was starting to rain.
Thanks, for the tip.
Hugger94
Old Mar 20, 2014 | 06:08 PM
billium's Avatar
billium
My son is trying do diagnose his driver side power window. When you hit the switch there is a barely audible whir.
Can someone please help us diagnose what to check?
Old Mar 20, 2014 | 06:10 PM
billium's Avatar
billium
He has the interior panel removed and we can see in, but nothing looks out of place.
Old Mar 21, 2014 | 05:27 PM
steve(ill)'s Avatar
steve(ill)
motor spinning, but gear box stripped ?? Plug in the switch and push the button while watching the motor.
usedtoolman
May 30, 2018 06:21 AM
RIKIL
Mar 7, 2016 09:54 PM
stv1991
Apr 5, 2015 08:41 PM
BigRobK
Jun 25, 2013 10:34 PM
kyledallas
19
Jan 3, 2012 04:42 PM
