Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Even More Frame Swap
Old Apr 28, 2006 | 10:32 PM
51dueller's Avatar
51dueller
Arrow Even More Frame Swap
Here's another update.
I put the 302 and AOD in the frame. Put in the driveshaft and it was good then bolted the frame together GOOD. I hope to get a local welder to come out and weld the frame together as my dad can't weld vertical welds to good. So now I can start to put on the body mounts. I need truck motor mounts as I have car mounts which don't work as good. Before I put the body on, I'm going to replace all the bushings in the front suspension.
Old Apr 28, 2006 | 10:41 PM
Fomoko1's Avatar
Fomoko1
It`s good that you are keeping us updated, nice to see your progress. Once my spring rush is over with the Bobcat I hope to have some time to work on the 56 M100 and the 53 F350.
Old Apr 29, 2006 | 12:35 AM
Dustin1690's Avatar
Dustin1690
Keep up the good work you sure do it fast
Old Apr 29, 2006 | 10:12 PM
51dueller's Avatar
51dueller
I plan on getting alot done this next week as I don't have to go back to work until thursday. If it starts to rain, I'll roll it into the garage to keep working.
Old Apr 29, 2006 | 11:03 PM
preppypyro's Avatar
preppypyro
Was just curious, are you going to paint up the frame too?
Old Apr 30, 2006 | 09:34 AM
51dueller's Avatar
51dueller
Yesterday I bought 2 cans of gloss black tremclad and a wire brush you mount in an angle grinder. I'm going to give the frame a good brush then paint it.
Old Apr 30, 2006 | 09:53 PM
Corner Gas's Avatar
Corner Gas
Looking good dueller, you're cruising right along.
Old May 1, 2006 | 11:52 PM
preppypyro's Avatar
preppypyro
Cool it will look really good
Old May 2, 2006 | 10:35 AM
Snowking's Avatar
Snowking
Maybe would it be worth powder coating, that's the new craze.
Old May 2, 2006 | 11:38 AM
51dueller's Avatar
51dueller
This a low buget build. Power coating would be nice but I would have to disassemble the entire frame, sandblast and then haul it an hour to a place to get it coated them bring it back home, assemble and hope I don't chip the paint.
Old May 2, 2006 | 01:58 PM
Snowking's Avatar
Snowking
My friend looked in to powder coating a stripped down truck frame for sandblasting and power coating is 400. Ain't cheap but still reasonable.
Old May 3, 2006 | 12:07 AM
preppypyro's Avatar
preppypyro
400 isnt that bad, but a guy can do things alot cheaper, I admire the low budget builds too.
JST2CRZY
Ford Truck Parts for Sale
Apr 29, 2016 10:41 AM
gdub
54
Feb 10, 2016 10:43 AM
gdub
22
Apr 12, 2012 10:24 PM
Red Ford Truck
Ontario Chapter
Aug 31, 2009 06:17 PM
Christopher2
43
Dec 5, 2004 10:07 AM
