2.8 no spark problem
Old Apr 28, 2006 | 07:56 PM
garycook1326's Avatar
garycook1326
Question 2.8 no spark problem
I have a 1984 ranger 2.8 4wd with manual trans. The problem is there is no spark comin off the coil. I have replace dist. coil, ignition module, ignition, checked all grounds and looked for any wires that may be groundin out. It started on my way home from work one day. it was like you turned the switch off. had it towed home then the next mornin it started right up and run for about 15 sec then the same thing. you can keep tryin to start it for a while and sometimes it will start and run. then you can go back the next day and nothing. the only other thing i can think of is the computer. it does it if its hot or cold. what do yall think. thanks
Old Apr 30, 2006 | 06:39 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Gryphon1962m
22
Apr 24, 2022 11:27 AM
Neoforcer
1997 - 2003 F150
Aug 1, 2016 05:04 PM
exidor12
Sep 13, 2015 06:34 AM
foobunny
May 15, 2015 06:43 PM
oneminizut
151
Aug 26, 2013 08:26 PM
