Modular V10 (6.8l)
V-10 Sound Clips Here...
Old Apr 28, 2006 | 01:55 PM
Port City's Avatar
Port City
Lightbulb V-10 Sound Clips Here...
Can we hear some sound clips of your V-10 exhaust system with explanation on what it is and how you like it???
Old Apr 29, 2006 | 07:55 AM
Fredvon4's Avatar
Fredvon4
none from me...pure stock exhaust is too quiet to record!
Old Apr 29, 2006 | 08:54 AM
Port City's Avatar
Port City
Yea, I know. When I stop at a red light the only way I know it's running is by watching the gas gauge.
Old Apr 29, 2006 | 09:10 AM
Big Cheese Stick's Avatar
Big Cheese Stick
I put a single inlet, dual outlet muffler in place of the extension pipe in front of where the original muffler was, ran dual 3" pipes out from there just in front of the right rear tire. Cost me $280 bucks complete. Has a REALLY DEEP rumble/drone at idle to 1,400 rpm, then goes dead quite after that (sounds cool going though parking lots, but can't be heard at all going down the road), its ideal to me!!!
Improved throttle responce a little bit. By the "feel of the seat", I'd say about five or ten more HP.
And having put a little over 400 miles on the truck since doing it, I'm getting about .8 mpg better under all conditions (empty babying it, romping on it, or towing 10,000 lbs.)
It also got rid of about half of the @#@$ ticking noise since several heat sheilds are now gone. (main reason I did it!)
BTW: This is the only mod. I've done to the truck that would effect performance at all. It's an '06, auto..
Old Apr 29, 2006 | 09:38 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
here's my 2001 stock unmodified exhaust:
http://fords.kilonet.org/krewat/v10-...ed-exhaust.mpg
Beware, the mpeg is 18 MEGS!
It's video, the sound is what you want, but watching the steam coming out in pulses from the tailpipe is priceless... so much for a restrictive catalytic converter...
Old May 1, 2006 | 11:06 AM
Port City's Avatar
Port City
Wish you had a sound clip.
THATS WHAT ALL THAT TICKING IS AFTER I SHUT THE TRUCK OFF!!! hmmmm
Old May 1, 2006 | 11:07 AM
Port City's Avatar
Port City
http://fords.kilonet.org/krewat/v10-unmodified-exhaust.mpg
Steam = ? BAD GOOD
I'm not a mechanic. I'm not even sure if I spelled it right ?!?!?!?!/ lol
Old May 1, 2006 | 12:47 PM
Sport45's Avatar
Sport45
Steam is okay. It's a product of the hydrocarbon combustion process. You can only see it when conditions are right such as a cool morning before the exhause system warms up. When everything is up to temperature the water vapor exits as an invisible gas.
Old May 1, 2006 | 12:56 PM
krewat's Avatar
krewat
Yeah, water is a by-product of the calaytic converter.
It also doesn't help that the truck was ice-cold when I started it up and ran it like that.
Notice it's still on high-idle?
Old May 1, 2006 | 04:43 PM
captchas's Avatar
captchas
Guest
it's from the darn pipes cooling down or heating up. mine is the same even with my fm 70 and no sheilds .tick tick tick.
Old May 1, 2006 | 09:30 PM
krewat's Avatar
krewat
Don't drive it so hard you heat everything up so much
Old May 2, 2006 | 09:35 PM
captchas's Avatar
captchas
Guest
esp.the rear tires we where at a test and tune track rental today haveing fun. with a camaro with a 576 2x4 carbed and dual nox hit.
playing around got the tow beast to do 16.2. with the stock reflash just done. now if i can get a copy of it and tuner play with it on my lap top with sct's proracer program.
heavyhauler797
Dec 19, 2016 01:27 PM
twobeer
Jul 22, 2015 05:04 PM
zcpro
Mar 8, 2014 06:02 PM
86f250XLT-4x4
Nov 10, 2012 06:38 PM
Chippenwhales
Feb 13, 2012 04:38 PM
