vacuum causing problems?????
Old Jul 15, 2002 | 10:03 PM
truckofdeath's Avatar
truckofdeath
Hey all,
Love my 1972 F-100, 302
I have my truck all back together now after a complete valve job, and it runs smooooth at idle. When I rev it up a bit, it start missing out and running rough (in Park). When I took off my vacuum lines to the Distrib to check my timing with my light, it purrs at all RPMS... Why is my vacuum advance causing this problem? I am sooo close to having my baby purrfect, this is making me a little nuts. Thanks Mike
Old Jul 16, 2002 | 05:36 AM
jowilker's Avatar
jowilker
Mike use the port on the other side of the carb.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jul 16, 2002 | 06:35 AM
Jimbare's Avatar
Jimbare
all alone in the world
make sure the breaker plate is not out of line in the dist. wiggle it around a little and see if it falls back into place.
Old Jul 16, 2002 | 09:40 AM
BB's Avatar
BB
Also make sure the breaker plate has that little ground strap attached.
Barry
Old Jul 17, 2002 | 12:20 PM
truckofdeath
WEll guys,
I tried both suggestions,
The plate inside my distib seems to be moving ok, and it seems to be working properly, and my ground wires are all attached properly, but still no luck.
My 72 302, has 2 vacuum lines. I'm guessing 1 to pull, 1 to push...
the come from the carb choke side, and the other from the back of the intake manifold...where would I find another vacuum source that isn't occupied?
or any other suggestions?
Old Jul 17, 2002 | 12:27 PM
Mil1ion's Avatar
Mil1ion
What carb is on that?
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 17, 2002 | 10:27 PM
truckofdeath
Post vacuum causing problems?????
well, I have a Motorcraft carb 2 bbl, but not sure exactly what model.
I checked my point gap, timing, and mixture/idle screws...all ok. The vacuum line that goes from my carb (near the auto choke) to the front of my distrib seems to be the problem.
when I pull it fro the distrib and plug it with my finger, it runs smooth. I am trying to find another port to try to get vacuum from...no luck..maybe I'm missing something?
Old Jul 18, 2002 | 12:19 AM
Mil1ion's Avatar
Mil1ion
>what model.
>the problem.
Do you mean : You pull the vacuum line and then plug IT or you plug the vacuum port on the carb?
The ported vacuum is on the right front of the carb below the choke housing.
Do you have a vacuum gauge ?
FTE Adminstration
[/font]
[/font]
Old Jul 18, 2002 | 08:58 AM
truckofdeath
I pull the vacuum line off of the distrib, the one that goes to the carb, and plug the line itself. I have a vacuum guage. What exaclty would I be looking for?
Old Jul 18, 2002 | 10:44 AM
Mil1ion's Avatar
Mil1ion
Pull the vacuum line off the vacuum port on the carb and replace it with the vacuum gauge hose.
At idle, there shouldn't be any vacuum >
Now, Rev it up and vacuum SHOULD appear < Thus being a ported vacuum line.
Have you tested the vacuum advance mechanism ?
get a vacuum gun ,place the hose on the vacuum advance port and watch to see if the arm on the advance pulls on the mechanism.
FTE Adminstration
[/font]
[/font]
Old Jul 19, 2002 | 01:43 AM
truckofdeath
I have to go out of town for awhile, so it seems my old truck willhave to sit unfinshed for a couple of weeks.
as a quick fix, I just pulled the carb vacuum line off of the distrib and shoved a golf tee in there to seal it. (like when you are using a timing light) but the other line I left atached to the distrib. I ran it about 40 miles today, and other than a slight hesitation taking off from stop signs (after it gets warm) it runs fine. I wonder if this isnt a choke problem? since that is where this vacuum line comes from..
Old Jul 20, 2002 | 10:02 AM
jds1971's Avatar
jds1971
I'll bet your vacuum diaphragm is ruptured.
Joe
Old Jul 20, 2002 | 06:12 PM
jds1971's Avatar
jds1971
