Airbag light flashing - Is it an error code?
Old Jun 7, 2006 | 05:22 AM
underthemilkyway's Avatar
underthemilkyway
Talking Hey Tim!!
Thanks ! Yes you will! Under
Old Jun 7, 2006 | 06:57 AM
subford's Avatar
subford
Originally Posted by underthemilkyway
32. What do I have to do to fix this? I would really appreciate any help. I just bought this vehicle. 94 E-250 . Thanks Under
When I got my 95 F150 I had a 32 also. It turned out to be an open wire in the harness. I cut both ends of the wire where it when in to the harness and came out and put a jumper to the two wires. I jumped from the main firewall plug to the plug for the left sensor. That fixed it and I have no more problems with it.
Old Jun 7, 2006 | 04:26 PM
underthemilkyway
Thanks!! I'll give it a try!
I really appreciate it Thanks again!! Under
Old Jun 7, 2006 | 06:27 PM
subford's Avatar
subford
By the way the wire that was open in the harness was a yellow wire with a light green stripe, wire number 625 but the Pink wire with a white stripe #619 could do it also.
Old Jun 7, 2006 | 07:57 PM
ceetwarrior's Avatar
ceetwarrior
So you guys have any idea why after pressure washing my floorboard would cause a problem??
Old Jun 7, 2006 | 08:39 PM
subford's Avatar
subford
What code is it flashing?
Old Jun 7, 2006 | 09:00 PM
ceetwarrior
Not sure, but the airbag light flashes five times in a row. Then pauses then flashes 5 times again.
I haven't had any problem until this last time.
Old Jun 24, 2006 | 10:46 PM
thebiggreenbeast's Avatar
thebiggreenbeast
Originally Posted by Zip
Yes I think that it is. Mine was doing the same with a code 2/7. I found the info here after doing a search. I fixed it myself as well. Good Luck
my 2000 f350 is doing the same thing & same code.CODE 27. what does it mean & how did u fix it?
Richard24
1997 - 2003 F150
Sep 6, 2012 07:59 PM
mbowker64
1997 - 2003 F150
Jul 26, 2010 11:24 PM
Fullcontact
1983 - 2012 Ranger & B-Series
Mar 8, 2006 06:58 PM
Knighticus
Jun 14, 2004 09:25 PM
Susan62
Feb 18, 2004 11:31 PM
