C6 Shudder
Old Apr 26, 2006 | 08:47 PM
Piffery1's Avatar
Piffery1
C6 Shudder
'83 F350 with 460 and ~75k (hard) actual miles. C6 shudders at about 5 mph accelerating or decelerating. Otherwise, seems ok. Fluid was brown but didn't have burned odor. Changed fluid (including drained converter) and filter and added Lucas treatment. Didn't seem to help. What next? What causes shudder?
Old Apr 26, 2006 | 09:09 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
torque convertor?, does it have a tranny cooler? the tq convertor could have gotten hot
Old Apr 26, 2006 | 09:26 PM
Piffery1's Avatar
Piffery1
Just the cooler built into the 4-row radiator. Transmission line to cooler has sending unit to underdash gauge and gauge has never shown hot since I've had the truck (~5 yrs.).
Old Apr 27, 2006 | 03:52 PM
rclarke's Avatar
rclarke
C6 doesn't have a lockup torque converter to cause the typical shudder problem. A very low speed shudder might be caused by a driveshaft/pinion angle problem. If you have a 2 piece drive shaft are the shafts in phase?
Old Apr 27, 2006 | 03:54 PM
ford390gashog's Avatar
ford390gashog
what fluid did you use Type F or Mercon/dexron III?
Old Apr 27, 2006 | 03:55 PM
restogreen's Avatar
restogreen
Try changing modulator valve. I don't think the clutch pack is getting pressure to cause engagement. Restogreen
Old Apr 27, 2006 | 05:15 PM
Piffery1's Avatar
Piffery1
Used Dexron III, operators manual called for II but according to Castrol bottle label III supersedes II. Two piece drive shaft phasing is exactly as shown in Ford manual. U-joints and carrier bearings have no detectable slop and no clanks or other noises. I forgot to mention, there is an external trans. cooler in front of the radiator which I think was factory installed on all 460's. I have a trans. fliud temp. gauge which indicates no temp. problems. I'll get a new modulator valve and try it, although I've had previous Ford vehicles with bad modulator valves that didn't produce this symptom.
56/78/92EFFIE
Nov 10, 2016 01:53 PM
AllThingsFord
28
Feb 21, 2014 05:09 PM
WuTang
Jan 31, 2012 11:13 AM
pb34
2004 - 2008 F150
Sep 2, 2011 07:41 PM
mpmccarthy
Jun 25, 2004 03:32 AM
