74 High-boy shifting problem
Old Apr 25, 2006 | 07:20 PM
Trailcat's Avatar
Trailcat
Hello everyone, I just acquired a 74 F-250 that runs pretty well but I have run into a problem with down shifting. The clutch seems fine as far as up shifting and starting but when its from 2-1 or 3-2 it grinds unless I get to a slow enough speed. Any suggestions? Thanks in advance.
Old Apr 25, 2006 | 07:51 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
sounds like an np435....i rebuilt mine and i fixed teh same problem....key is the syncro shims and the endplays.....dont expect this tranny to shift like a zf-6 or something though
Old Apr 25, 2006 | 07:52 PM
ken selvy's Avatar
ken selvy
Try running red line synthetic , I did and I have 340000 miles on a borg warner 4 speed , goes into gear smoothly.KFLORD77. Just a suggestion!!!
Old Apr 25, 2006 | 07:57 PM
KubotaOrange76
whats the api rating or whatever its called on the red line??? ive always heard th 435's syncros dont like the newer gl5 gear lubes but i cant find anything gl4 or older
Old Apr 25, 2006 | 10:16 PM
Trailcat's Avatar
Trailcat
Thanks, will try the fluid first and the rebuild if that fails.
Old Apr 25, 2006 | 11:07 PM
FordPickup460's Avatar
FordPickup460
The tranny shouldnt go into 1st gear without double clutching and/or matching the rpm's unless you are stopped as its non-synchronized, the grinding is normal there. Most of the NP435's ive seen, and my own, dont like to downshift to 2nd unless you double clutch or match the rpm's.
Old Apr 25, 2006 | 11:15 PM
KubotaOrange76
same here...usually if theres grinding in the 3-2 shift they are getting worn
Old Apr 26, 2006 | 07:16 PM
Tractor Boy's Avatar
Tractor Boy
I know this may sound dumb, but one of mine was converted (3 speed Ford trans) from column to floor shift and it wont grind when I down shift, it simply wont let me move the shifter into that gear, I like it, but just wonderin if its made to be like that, it has a B and M floor shifter kit installed by the previous owner so maybe that also has something to do with it
cjeffers9
May 10, 2010 05:32 AM
Bugk
Dec 29, 2008 07:05 PM
juchertf100
Sep 22, 2008 06:53 PM
74F250
Feb 5, 2002 09:04 AM
fasch74
Dec 21, 2001 01:29 PM
