radiator-power steering?
Old Jun 29, 2002 | 12:27 AM
comertrucks's Avatar
comertrucks
Hello I just got done rebuilding a 410 for my 70 F-250 4x4 and had to buy a new radiator for it. But my truck has a 4spd so I don't need the cooler. I was wondering if anyone has hooked up thier power steering return line to the cooler in the radiator? Would it work? I thoutgh the temps might be to close or the radiator might be hotter than the power steering fluid which would make it pointless. The reason I ask is that the drive from where I work to where I live is all uphill and by the time I get home the pump is whining. Yes I have checked the fluid. Thanks for your help and input. comertrucks
Old Jun 29, 2002 | 12:55 AM
sparky's Avatar
sparky
Hey neat idea I do not see why it wouldnt cool the fluid. Although I have never heard of it being done...... but someone has to be first.
Sparky
Old Jun 29, 2002 | 09:16 AM
comertrucks
Thanks. But I still need to know about the temp differeces. Will there be enough difference for it to have a coolng effecct on the power steering fluid? Thanks again for the help.
Old Aug 6, 2002 | 01:07 AM
ford390fourx4's Avatar
ford390fourx4
i have a 69 f-250 4x4 pickup that i put a 78-79 power steering box into. i have a radiator out of a truck that used to have an automatic. i ran the return line through the tranny cooler and haven't had any problems at all. this keeps the fluid at a more constant temp and everything works great.
Old Aug 6, 2002 | 11:22 PM
Mike W's Avatar
Mike W
Looks like a good time to put a temperature gauge on the power steering pump. "I like to measure everything"
Old Aug 6, 2002 | 11:36 PM
Nod's Avatar
Nod
Hey Mike,let us know how it all works out,that might be the answer to cold-slow-winter power steering problems.Any idea how much volume is in a standard V-8 radiator for tranny oil?
"bowties in the rearview mirror"
Old Aug 7, 2002 | 12:03 AM
comertrucks
Thanks. I knew someone out there had thought of using it to cool the power steering fluid too. I was driving around tonight on some dirt roads and I think it got hot, the pump was whining like the fluid had air in it. I will try it as soon as i get my carb dailed in. Thanks again.
Old Aug 7, 2002 | 10:59 PM
Mike W's Avatar
Mike W
This is probably a real good idea. I know that the power steering fluid can get too hot. I have never seen any specs on how hot. My f-250 has the little cooler on the return line. Don't remember seeing this on cars.
Old Aug 8, 2002 | 09:52 AM
BB's Avatar
BB
Hi Mike, some of the full-size cars and station wagons had a little p.s. cooler mounted off the a.c. compressor. I adapted one in my Mach1, looks stock.
Barry
Old Aug 8, 2002 | 09:04 PM
jds1971's Avatar
jds1971
You guys are thinking in the right direction, but instead of using the rad trans cooler, it would be best to use a small trans cooler mounted in front of the radiator. This way, you are cooling the fluid down even more so than the temp it would reach in the rad.
Joe
Old Aug 8, 2002 | 11:00 PM
FTE Ken's Avatar
FTE Ken
jaleus
Nov 18, 2022 12:01 AM
GMGUYTHATOWNSAFORD
Nov 22, 2016 03:05 PM
fishwhenican
Sep 30, 2016 01:30 PM
rv7plt
Nov 13, 2015 01:45 PM
filthy6
17
Sep 21, 2015 12:11 PM
