Oil & Lubrication
UOA's!!
Old May 14, 2006 | 05:40 AM
gusher's Avatar
gusher
Flash ,you go look at the charts that list the acceptable levels of metals, you will find that 38 ppm is on the lower side of what is acceptable.
Old May 14, 2006 | 11:08 AM
Flash's Avatar
Flash
Gusher, what you are looking at are the universal averages for THAT lab only. Considering that his UAs are exactly the same as his report, they apparently don't have any or many in their data base. Go to a different lab, different universal averages.
Old May 14, 2006 | 11:39 AM
furball69's Avatar
furball69
My Unit/Location averages are for my particular engine, I've only sent one sample in, so those won't change until I send in another sample. The Universal averages are in the far right.
Old May 14, 2006 | 08:00 PM
Rockledge's Avatar
Rockledge
A UOA helped me nail down a leaky lower intake gasket, indicating high levels of sodium and potassium (coolant) in the oil:
1998 Ranger 4.0L UOA Results
Old Feb 12, 2009 | 08:37 PM
exspensivev10's Avatar
exspensivev10
just curious
Originally Posted by scafes
True, if your not extending OC's then its probably not worth it. How much oil does your V10 hold? A 6.0 holds about 17qts, that gets expensive to change. OA gives you alot of info to keep track of not just the oil, but the condition of the engine in general. You'll know if a gasket is going by the coolant reading, if you have too much fuel dilution, and the best part, being able to track the wear pattern of the engine. You will see the wear as the engine breaks in then the wear will level out. To each his own, I intend to keep my truck for many miles and be able to proactively anticipate maintenance.
If ur saying the 6.0 v10 holds 17qrts. how much does the 2003 6.8l v10 hold?
Old Feb 12, 2009 | 11:53 PM
azfordf100man's Avatar
azfordf100man
No, the 6.0 V8 Diesel, which holds 15qts. I believe that V10 holds 6qts.
slowmans
6.4L Power Stroke Diesel
Jul 17, 2012 12:11 PM
ernesteugene
16
May 18, 2010 01:03 PM
cartmanea
Sep 30, 2009 04:33 PM
BrianA
Oil & Lubrication
20
Aug 12, 2004 03:53 PM
Rockledge
Oil & Lubrication
Jun 3, 2004 10:42 AM
