Vacuum Activate Hubs special tool?
Old 04-24-2006, 02:05 PM
kidder's Avatar
kidder
kidder is offline
Hello,
I have 98 4x4 Ranger with vacuum activate hubs. I had removed one of the plastic hubs 1-2 years ago to service the hub seal. I had a real hard time removing the hub at that time. I now believe that one of wheel bearings \ hubs is failing. I just got one of the Ford Service Manuals now. It shows a special tool to remove the hubs – is this necessary? I was using 3-4 screw drivers to remove it. Also in the Ford manual it shows the hub having a replaceable needle bearing. What is the deal with the needle bearing? I called my Ford dealer’s parts department and they seemed confused as to whether the new hub came with the needle bearing installed? Finally, where is the cheapest place to get a hub?
Thanks in advance.
Rick
Old 04-25-2006, 07:01 AM
kidder's Avatar
kidder
kidder is offline
bump.. so one has to know this??????
Old 04-27-2006, 07:06 AM
kidder's Avatar
kidder
kidder is offline
Crazy
This is nuts there are about 200 post on all the issues with these type of lock out hubs. No one has any infomation on my post? Thanks
Old 04-27-2006, 07:56 AM
fordboy_52's Avatar
fordboy_52
fordboy_52 is offline
yes there is a special tool. in my haynes it lists a lerge socket looking tool. im guessing its around a 2.5 inch? go to your parts store and tell them you need the hub tool. im almost pos they will have it on hand
Matt
