p1211 ?'s
Old Apr 24, 2006 | 01:08 PM
88_150's Avatar
88_150
p1211 ?'s
I did a search for this code and everthing I found related to it being common when running a chip or tuner. I reprogrammed my truck back to stock about a month ago and now I am getting this code .
When I ran with the scmt on max performance, I never saw this code.
I am also getting p0470 along with the p1211. The truck runs great, I get the code when I get on the pedal to pass or speed up, the SES light comes on and does not go out until I shut down and restart. If I drive it like theres an egg under the accellerator I never get the SES.
I have a 4" dp & exhaust, kwik filter and pillar pod. The boost seems normal runs up to 17 or 18 psi when in stock tune.
Any ideas?
Thanks
Bill
Sorry, this should have been posted in the 1999-2003 7.3 forum, moderator, please move this thread.
Old Apr 24, 2006 | 01:40 PM
ForemanES's Avatar
ForemanES
0470 EBP Exhst press sensor ckt malfnct (96 MY) No-start or crank mode Biased sensor, open signal return
1211* IPR ICP pressure above/below desired Continuous and KOER on-demand test IPR valve failed, stuck, or shorted to ground
I bet the superduty guys will have an explanation why your getting these codes.
Old Apr 25, 2006 | 10:26 AM
erl_berner's Avatar
erl_berner
Sounds dumb but i recently threw a P1211 due to my oil change being a little errant (over 3000 miles).
Changed the oil and it went away...
sudsmcduff
Nov 14, 2015 06:10 PM
Slyhuntr
May 15, 2015 02:00 PM
sudsmcduff
Apr 9, 2015 08:06 AM
aussie_f350
23
Aug 30, 2013 09:13 PM
wolfe1104
May 4, 2007 05:50 PM
