AMP guage hookup
Old Apr 24, 2006 | 05:38 AM
ford4604bbl's Avatar
ford4604bbl
AMP guage hookup
I have a 75 F250 A friend of mine gave a set of guages (oil,temp,amp) well I knew how to hook up the oil and temp but I have no idea on the amp guage ...can anyone help me out ?
Old Apr 24, 2006 | 10:22 AM
FalconStng's Avatar
FalconStng
usually the 3 gauge set has oil, temp, and voltage...not amps. For voltage one side of the gauge gets 12 switched power...only on when switch is on...and the other side gets grounded. For an amp meter usually you measure the amp draw of the accessories only...not the amp draw when you're starting...still not difficult to wire but you need to know what you're doing for the amp meter.
Good Luck!
Tracy
Old Apr 24, 2006 | 11:41 AM
Mil1ion's Avatar
Mil1ion
First of all it's called an Ammeter not an amp meter.
Here's how to hook it up.
http://www.gmceast.com/amp.htm.
Maybe read this first though.scroll down to ammeter vs voltmeter
http://www.chevelles.com/techref/tecref20.html#4
Old Apr 24, 2006 | 01:52 PM
ford4604bbl
Thanks guys ..so what ...it isn't reading the amps??? just the amms? I thought it was a measurement of the amperes? Sounds like I would be better off with a volt meter than to mess around with the ammeter. If I do decide to hook up the ammeter what guage wire will it require?I have no instructions on this stuff.
Old Apr 24, 2006 | 02:08 PM
FalconStng's Avatar
FalconStng
gee Dennis....coming from TN most people call em dohickeys so I thought I did pretty good with amp meter....LOL.
YOu could have either one but the voltmeter is much more common. It should say on the gauge...what #'s are on the gauge?
Tracy
Old Apr 24, 2006 | 02:26 PM
ford4604bbl
It is an Ammeter not Volt ...reads 60-0-60 and says AMPS on the face of the guage.
Old Apr 24, 2006 | 02:32 PM
FalconStng's Avatar
FalconStng
There ya go...I humbly apologize for bringing up the voltmeter stuff. As long as your alternator can't put out more than 60 amps then you can use this. Check Dennis's link out above...that's how to hook it up.
Good Luck!
Tracy
Old Apr 24, 2006 | 04:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
An ammeter is a good fire starter...
JHarsh
21
Dec 2, 2014 08:17 AM
Country_boy_2007
Feb 1, 2011 08:08 PM
TractorM3
Apr 13, 2009 12:26 PM
1975Ford
25
Jan 25, 2007 08:19 AM
