Sponsored by: Kumho
Brake pull
Old Jul 6, 2007 | 10:31 AM
vettdvr's Avatar
vettdvr
I really suspect the brake pads. But you must check.
1) caliper for leaks
2) hoses for cracks/damage
3) slide pins on the calipers
4) rotors
5) pads
I found that after doing 1,2,3,4 the pads were the cause. Could see no defect but when replaced braking went to straight stopping.
I would suggest just pull the calipers clean the pins and change the pads to see if it solves your problem.
Also I used Wagner Ceramic Premimum pads which appear to have same stopping for lower pedal pressure with out the black dusting of the chrome wheels.
Old Jul 6, 2007 | 06:11 PM
Luecker's Avatar
Luecker
I pulled the front off yesterday and they were fine. I lifted up the rear end and the left tire has some drag and scraping. Looks like I get to put in new pads and possibly a caliper.
Old Jul 6, 2007 | 07:04 PM
vettdvr's Avatar
vettdvr
I agree if you have dragging it must be corrected. The same work applies to the rear. But if you finish the rear and still have the issue, don't feel bad about changing the pads. But given 144000 miles on your truck be sure to check the brake hoses to the caliper for cracks. I replaced all of mine at 132000. Jim
Old Jul 6, 2007 | 08:07 PM
Luecker's Avatar
Luecker
Pads were gone on the left rear. Caliper seems to be working just fine. Will pick up new rotors and pads tomorrow. That should take care of the problem.
I will check the lines as well. Thanks for the advice.
avenge
Oct 2, 2012 11:45 AM
JoSHN
2004 - 2008 F150
Oct 1, 2011 07:29 PM
mechelement
19
Feb 4, 2009 05:02 PM
dagren99
Feb 5, 2008 03:26 PM
CPB
May 4, 2004 05:08 AM
