1978 - 1996 Big Bronco
What lift?
Old 04-23-2006, 12:14 PM
Ford94Bronco4x4's Avatar
Ford94Bronco4x4
Ford94Bronco4x4 is offline
What lift?
I want to lift my bronco. I was looking at putting BF Goodrich All Terrain TAs on that are 35 x 10.50 x R15. Whats the smallest lift i can put on without the tires rubbing. It is a 1994 bronco eb 4x4. Also, should i get a body lift, suspension, or a lift kit to accomadate the tires
Old 04-23-2006, 12:43 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
The FAQ's list tire sizes according to the amount of lift required to clear them. You have two options with lifts body or suspension. Personaly I have no use for body lifts they do nothing but interfere with the strutctural integrity of the truck in the name of getting a couple extra inches of tire clearance in the wheel wells. They are considered to be less expensive but require a good deal of tweaking of things that a suspension lift doesn't even touch. Suspension lifts are considered more costly but do improve ground clearance by more than just the increase in tire diameter. In short, suspension lift would be my recommendation but research the livin' daylight oput of the project before making a decision. Keep in mind too that moving from the stock tire size up to 35's is a major jump and will require re-gearing the axles unless you want a Bronco with half the kick in the pants and twice the thirst that it had before you lifted it.
Old 04-23-2006, 12:50 PM
Ford94Bronco4x4
well would like 32s or 33s with no lift fit in, and still have some get up and go in it?
Old 04-23-2006, 01:06 PM
greystreak92
32's are still ok and won't require any lift in most situations. But bigger than that and you begin to lose your passing a hill climbing power. I ran a 92 with 33's and the stock gearing and the mileage and the power just went out the window. I am going under the assumption that your Bronco is equipped with the OEM 3.55:1 axle gear ratio. 4.10:1 was an option in these trucks but its a rare one that late in the production run.
Old 04-23-2006, 02:37 PM
Ford94Bronco4x4
yeah it has a 3.55
Old 04-23-2006, 09:26 PM
helirich's Avatar
helirich
helirich is offline
One option you have is to not lift at all and just use cut out fender flares. (bushwacker) In vertually all off road and on road situations, The less you lift, the better. (except in deep water fording) Off road, the bigger the tires, the better. Of course you must lift if the tires get to big. As far as the gear change, the milage actually gets better if your truck has the ***** to drive it in overdrive. The problem is most trucks dont, so you end up running in 3rd at 70 with the engine screeming. My old truck (302) was like that untill I changed to 4.56 gears. I think my new truck (351) would have done it, but I went to 4.88 with 38" tires.
Old 04-23-2006, 09:31 PM
helirich's Avatar
helirich
helirich is offline
I forgot to mention, Greystreak is right about the power. It also has a tendincy to burn up your first gear clutches.
Cool1996
06-19-2013 11:13 AM
Jay94250
Offroad & 4x4
02-28-2007 11:05 PM
351Bronco
16
12-26-2003 03:57 PM
grifter0
10-08-2000 09:26 PM
vdub8
08-30-2000 08:42 PM
Quick Reply: What lift?
