help, I have a 1999 ranger 4x4 w/auto hubs. My rotors (front) need to be replaced and I cannot afford a dealer. I have ok mechanical knowledge. I bought a chilton and the info was poor. any suggestions? I have heard that special tools are needed and my local auto parts in not much help. Is there anyone who has replaced the rotors who would spend a few moments outlining the steps and tools needed?? THANKS!! Travis
Why don't you pull the old ones and have them turned at a machine shop, it's pretty cheap and will provide the same effect. If not, new ones aren't too expensive.
No idea...parents did it for me. I'll ask. I assume they were MC. We kept having the brake dust cover the wheels so they stole my truck one morning and took it to the mechanics, told me they were going to meet some friends, took the other truck as well, that afternoon, after I called the police to report my vehicle un-stolen, I was quite a happy camper lol.
I have a 2001 F150 4 X 4, and I did my first front brake job today, including replacing the rotors. I'm guessing that the 1999 is similar. Take off the wheels. Then loosen & remove the two bolts (18mm hex head) that hold the caliper to the hub; they're on the backside of the hub. But don't let the caliper hang by the brake hose, support the caliper by a wire or on a stool. The rotor may come right off, but most likely it's somewhat rusted to the hub. Now you have to tap firmly around the rotor until it comes loose. I used a 3 lb hammer and had to tap from the backside as well as the front. New rotors were $25 each at the auto parts store. I replaced the brake pads also, another $50. You'll need to open the calipers by compressing the pistons with a large C-clamp before you put the new pads on; otherwise you may not be able to put the caliper on the new rotors. There are no special tools needed, just an 18mm wrench or socket and a large C-clamp. The pads come out with no tools, just fingers. Push the pads toward the center of the caliper. The whole thing is surprisingly simple, although it takes a while to figure it out the first time.
That's actually pretty close. I know my bro's '01 4x4 F-150 was very similar to my own brakes. You're not that far off. Maybe the sizes are off, but the process is more or less the same.
Can vouch for that as well. I changed rotors on my old 99 Ranger a few years ago. The sizes were probably different as nate mentioned, but everything else in the process was the same... If you don't have a manual, such as Haynes, I think Autozone's website might have some online ones. I think I remember seeing front pad and rotor removal and installation instructions for the 99 Ranger. Not sure how detailed they are, but it's worth a shot anyway.
