71 f250 w/360 engine.
Old Aug 17, 2002 | 03:52 PM
superdutyman's Avatar
superdutyman
I saw a 71 f250 with 64000 miles with a 360 automatic.
I've never heard of a ford 360 can anyone give me some information on it? thanks
Old Aug 17, 2002 | 04:35 PM
0u812's Avatar
0u812
Post 71 f250 w/360 engine.
This is a FE big block motor which is basicly a destroked[for torque] 390 . Many poeple mistakenly think they have a 390 in there truck when in reality its a 360. Ford had 361's [bigger clearances] they used in dump trucks and such. These are stout motors and with proper maintenence can rack up high miles. TO me there biggest downfall is gas milage I,ve never been able to get decent milage out of one. they w,ere designed when gas was $.35 a gallon and that was not a problem back in the day. A book on early big block FE motors would tell you probably more than you want to know!
Old Aug 17, 2002 | 05:05 PM
superdutyman
thanks Sundog, I appreciate your response. Would you know where I could get some specs. on hp. etc... thanks again for your help.
Old Aug 18, 2002 | 10:53 PM
0u812's Avatar
0u812
There was a book titled Rebuilding your big block Ford .I can't remember the authors name . It was softbound and I bought it at a speed shop. Good photos and excellent tips and tech. info on all big block FE motors The author had a thing for 427s wich are a member of this family and there is interesting reading on that. I rebuilt several 360/390s using this book with good results. I loaned it to a friend and have not seen it in years. Wish I still had it! Hope you can find a copy of it.Good luck!
Old Aug 18, 2002 | 11:47 PM
buzzard's Avatar
buzzard
The 360 has around 215 hp and about 325 ft. lbs. torque while the 390 has around 255 hp and 375 ft. lbs torque.
Old Aug 19, 2002 | 11:29 AM
sullyda1's Avatar
sullyda1
The 360 is a bored out 352 motor. 360 bore = 4.05": 352 = 4.00". All parts interchange. Same crank and rods. Heads have slightly morer cc's. As previously pointed out, for some reason they were terrible on gas mileage.
Old Aug 19, 2002 | 06:22 PM
jowilker's Avatar
jowilker
Dave, I disagree, The 360 is a 390 block (same bore) with a 352 rotating system. A detuned 390 it is, for early emmisions.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Aug 19, 2002 | 06:47 PM
jds1971's Avatar
jds1971
[updated:LAST EDITED ON 19-Aug-02 AT 07:48 PM (EST)]Hey fellas-
I was looking through an old Chilton for '65-'80 ford trucks. For the 70-71 models with a 360, they list the compression ratio to be 8.4:1 . For the same years with a 390, they show it to be 8.6:1 . Both engines have 2bbl carbs. Does that sound correct? How does that translate into horsepower?
Thanks-
Joe
Old Aug 20, 2002 | 07:24 AM
jeremyd72's Avatar
jeremyd72
Kriswat33
Apr 27, 2017 04:33 PM
Chris71f250CS
Dec 21, 2016 01:37 AM
highboyrick
Feb 29, 2016 04:04 PM
mattg12b
May 20, 2006 06:02 AM
71F250camper
15
May 2, 2005 10:36 AM
