bed help please
Old Apr 21, 2006 | 10:09 PM
BIG66PROJECT's Avatar
BIG66PROJECT
Cool bed help please
sorry this is a generic question, I spent hours trying to take the bed off my 66 long bed, is the bed floor rivited to the cross member. it is kickn my butt, I only have basic hand tools any suggestions?
Old Apr 21, 2006 | 10:22 PM
FirstTry's Avatar
FirstTry
if you have the toolbox in the bed side it has some bolts and screws that i think you have to take out, as well on mine at least there are two bolts i found in the back that are under the floor attaching to the bumper that you cannot see from the outside. i think this applies to yours as well. mine has had some "farmer" repairs and that could be where these bolts come from.
Old Apr 22, 2006 | 05:24 AM
jowilker's Avatar
jowilker
I have found that an air wrench, and someone standing on the carrage bolt to keep it from spinning is about the best method short of the blue tip wrench or saws all. 8 bolts for the long bed and 6 for the short. Once they spin in the hole you might as well stop wrenching them. IMHO
John
Old Apr 22, 2006 | 04:22 PM
mikecarson's Avatar
mikecarson
8 bolts in the short bed, also.
Old Apr 22, 2006 | 06:08 PM
daveengelson's Avatar
daveengelson
Once bolt starts spinning found a 41/2" grinder w/ cut-off disc works. When it really gets serious, have used cutting torch. Heating nut and striking w/ heavy duty hammer, rather than using the oxygen for cutting may be able to avoid heating frame too much. Came across tool box/storage compartment in a salvage yard and only had a chisel available. Few blows with sharp chisel was able to drive the nut off. Have removed by carefully grinding head using 41/2" grinder w/ grinding wheel until able to drive the bolt thru, even using care still will be couple slips.
dave
Old Apr 23, 2006 | 11:46 AM
BIG66PROJECT
Smile grinder
I've had it I think the angle grinder with the cut off wheel is my only option at this point,I have a new bed so not to worried about fubaring anything
Old Apr 23, 2006 | 07:00 PM
BIG66PROJECT
bed is off and the 41/2 angle gringer with the cut off wheel did the trick!!!!!!!!
Old Apr 23, 2006 | 11:09 PM
Putt's Avatar
Putt
Hopefully it didn't take all 8 hours between posts!!!?
Old Apr 23, 2006 | 11:40 PM
BIG66PROJECT
no my cheap angle grinder took a dump on me had to go buy a new one,and I live in a very small town and finding tools on a saturday is a challange
Tdog71
Aug 11, 2013 08:23 AM
dullchrome
Jan 2, 2011 09:10 PM
PawPaw's '66
Aug 25, 2009 05:01 PM
bgsuarez
Apr 26, 2005 04:56 PM
spurredon
Jun 16, 2004 01:18 AM
