Vibration at certain speed
Old Aug 21, 2002 | 11:13 PM
boss351's Avatar
boss351
I am trying to solve a vibration that appears in the 45-55 mph range which can be felt in the steering wheel. I have replaced the Ford power steering gear box and the radius arm bushings on my 1971 F100 Ranger Xlt lwb.(2wd) Also the front shocks and tires are new. The vibration smooths out as you accelerate on thru 55 mph. Could this be a drive shaft(s) issue? Even with the new steering box, it seems that the steering is slow to respond and tends to wander. (You really have to pay attention while driving) Is this a sign the king pins need replacing? Everthing else is stock suspension underneath. The original 360 engine has been replaced with a 1976 302ci.
Thanks for suggestions in narrowing down the source of the vibration!
Steve
Old Aug 22, 2002 | 01:16 AM
Scotty1's Avatar
Scotty1
It could be a drive shaft problem, but if it is felt through the steering wheel my bet would be the front end is out of align. If it is still wandering around you may need to replce the bushings in the steering linkage. There about 4-6 of them I can't rember for sure an exact #. Poly bushing kits can be had most places on line. I think Prothane makes a kit for the 67-72 ford trucks. I hope this helps.
Scotty
Old Aug 22, 2002 | 07:49 AM
FE427TP's Avatar
FE427TP
are the radius arm bushings in good shape?
Old Aug 22, 2002 | 09:11 AM
Tedster9's Avatar
Tedster9
Can be hard to pin down, but be sure to check your hanger bearing on the driveshaft.
Keep 'er between the ditches.
Old Aug 22, 2002 | 09:45 AM
buzzard's Avatar
buzzard
If I were a bettin' man, I'd say it has something to do with tires/balancing.
Old Aug 22, 2002 | 05:20 PM
Hawkeye58's Avatar
Hawkeye58
Since you have done the radius arm bushings, as well as the tires, and power steering. Now it's time to look at the axle pivots and the tie rod ends and drag link.
I agree too with the front end alignment.
Keep going and eliminate all points of link and pivot. You have a good start. These trucks are old and the wear and tear will require all the points reconditioned, I'm betting.
Good luck!
Hawkeye
Old Aug 22, 2002 | 10:21 PM
Mike W's Avatar
Mike W
Once you get all the play out of the linkage, go to an old time alignment shop that knows how to set the castor. This will take care of the wandering. It did on my F-250.
Old Aug 23, 2002 | 11:06 AM
Brian's Avatar
Brian
Have you actually checked the play in the steering box? Is it a rebuilt unit or brand new. I bought a rebuilt unit for my 66 4x4 and it was great for about 2 weeks. I drove it for another year before it was as bad as before I bought the rebuilt unit. I took it apart and there are welds inside that were broke. The rebuilder rebuilt it for free. In the mean time I found a 40 year old ford unit that works great.
The moral is; Don't eliminate the components just because they are new.
Old Aug 23, 2002 | 08:54 PM
boss351's Avatar
boss351
Hey guys,
Thanks for the input. I will start with the alignment and see what shakes out as problems. The steering gear box is new and should be based on how much it cost. However, I will go back to the mechanic who installed it to check it out. Thanks again.
Steve
Old Aug 26, 2002 | 08:00 AM
Oooh1956's Avatar
Oooh1956
As Align goes do you drive your truck mostly empty or full? I was ASE frontend Tech and found that all ford trucks are align'd as loaded with 0 to -toe to compensate for loaded truck. If you run mostly empty then ask you align tech to toe in .06 to .12 This will help with driving and tire wear. Hope this helps
Old Aug 26, 2002 | 11:52 AM
buzzard's Avatar
buzzard
>Hope this helps
My original Ford spec books show minimum toe-in at 0.06", maximium toe-in at 0.19" and optimum at 0.125".
I still don't think an alignment will cause vibration at certain speeds. When I worked in a tire shop, the vast majority of vibrations were caused by bad tires and/or improper balance. Just because you have new, newly balanced tires, don't think you cannot have problems.
Old Aug 26, 2002 | 08:21 PM
jds1971's Avatar
jds1971
[updated:LAST EDITED ON 26-Aug-02 AT 09:24 PM (EST)]I second that, Jim. Steve, the balancing job on your tires is only as good as the monkey that balanced them- take that into consideration.
I've driven trucks where the front end was as sloppy as a soup sandwich and they never vibrated, just shimmied from side to side a little.
Good Luck-
Joe
Old Aug 26, 2002 | 08:42 PM
Mike W's Avatar
Mike W
[updated:LAST EDITED ON 26-Aug-02 AT 09:43 PM (EST)]I have heard of vibration cases that were finally resolved by truing the tires (cutting off a little bit of rubber to make them round).
Old Aug 26, 2002 | 09:00 PM
Like M. Fords's Avatar
Like M. Fords
nvann001
1997 - 2003 F150
Nov 29, 2016 12:24 AM
sunuvabug
Jan 5, 2015 04:55 PM
dines78
Dec 10, 2012 07:35 AM
the78ranger
Jul 16, 2012 06:16 PM
expo54bx
Oct 2, 2010 12:52 PM
