Duraspark Conversion trouble
Old Apr 20, 2006 | 03:54 PM
Ponyexpress's Avatar
Ponyexpress
We removed a points type 352 out of my Dad's 66 F250 and installed a 428. This motor came with a duraspark dizzy. I installed the rest of the components but the motor won't run; it will fire but it won't run. I have the white wire connected to the start terminal. The red wire connected to the red/green wire at the key. I am using the factory harness including the coil plug. I am using a new MSD coil for duraspark ignitions. I have 12 volts on the red wire when the key is on and cranking. I have 12 volts at the coil when the key is on, then it drops to about 9 volts when the engine fires and dies, the voltage returns to 12 volts. I have changed boxes--not fixed. I have 12 volts on the "I" terminal when the key is on. We are at a lose as to why it won't work. I need to get it running. I will put the points dizzy back in if I have to please help???
Old Apr 20, 2006 | 04:05 PM
Ringo Fonebone's Avatar
Ringo Fonebone
The pink wire coming off your ignition switch is a resistor wire, which when in "Run" mode (as opposed to "Start" mode, reduces the voltage to your coil to 9 volts. Duraspark runs on a consitent 12 volts. In other words when you turn the key to start on a stock ignition setup it feeds 12 volts temporarily to the coil for starting. when you release the key to run, it switches to the pink wire.
Bypassing the pink wire will eliminate this problem, but my truck was a 351W with the duraspark setup when I got it, and it ran just fine like that.
I bypassed the pink wire to get more coil voltage, but it still ran the other way. So that may not be your entire problem.
RF
Old Apr 20, 2006 | 07:14 PM
daveengelson's Avatar
daveengelson
Have 390ci and 302ci in 65's and wired both the same. Ran a search in both yahoo, & google and found bit of info. Also, search in FTE forumcame up with some additional info. Here are couple site may find helpful.
http://geocities.com/mustang_man_1966/duraspark_ad.html
https://www.ford-trucks.com/forums/s...d.php?t=245030
Seems last day or so, experiencing difficulty linking to some of the FTE threads, hopefully, those posted above will link up.
dave
Old Apr 21, 2006 | 04:50 AM
jowilker's Avatar
jowilker
I got the FTE one to work, and it was not an FTE error.
I am not sure that the other page is available.
John
Old Apr 21, 2006 | 08:40 AM
PROSTOCK's Avatar
PROSTOCK
Pony, I have done the said conversion on my '65 F250. At lunch I will inspect the wiring. I remember it being a much simpler install than you have described. But I also agree that you may have other issues. Personally, I am not a believer in MSD products, as I have had more trouble than I should.
Tune in this afternoon for my wiring detail. It is a great conversion.
Old Apr 21, 2006 | 08:41 AM
garbz2's Avatar
garbz2
Reverse the white and red green wire.....
Garbz
Been there and done that to Sincs slick when we did the overhauling to it. Ran when cranking but not on run.. switched the wires and she is still running like a champ.
Garbz
Old Apr 21, 2006 | 08:57 AM
Ponyexpress
GARBZ2 wins the prize! The plugs for the red and white wires are reversed; at the box they are in one position but the other end they are reversed. I thought this was strange but my '87 F250 are the same way. It needs to be wired as the picture shows and it will work. We reversed the wiring and the 428 came alive!!!! Thanks for your help!
Old Apr 21, 2006 | 09:09 AM
garbz2's Avatar
garbz2
I like J.W. Dundee Honey brown...................mail me a six....
Garbz
Old Apr 21, 2006 | 09:11 AM
PROSTOCK's Avatar
PROSTOCK
Dad-gum it garbz...you stole my 6!
Lascar
Feb 27, 2015 02:57 PM
jlj6t
15
Apr 10, 2011 05:02 PM
sschroeder
Electrical Systems/Wiring
Sep 24, 2009 11:45 AM
doctorolds
21
Jul 31, 2007 09:48 PM
